11-03-2016, 03:14 PM | #23 |
Rep 203
This may be a dumb question but I'm confused An figured I'd ask for clarification. When do you need one of these? I have msr intakes haven't had the car tuned yet. Waiting for dp then tune in the spring. Thanks for clarification in advance
11-03-2016, 05:45 PM | #24 |
Rep 2,062
Oil fumes/vapor gets sucked into the combustion chamber, coating the intake walls, leaving carbon deposits on the backside of the valves and ultimately making the car lose power. The S63TU has a better PCV/CCV system than the S63, but both still suck at the end of the day. A catch can takes the oil outta the intake system at the expense of you've gotta empty it every few months. Read the link I posted, it's quiet detailed.
Bostons_Finest_147.00 |
11-04-2016, 12:06 PM | #25 | |
Rep 881
So you put an oil catch can between the PCV valve and the intake to capture that oil. I'm not really sure how efficient the M5 PCV system is, but I do get a little oily residue in my passenger intake pipes.
2014 "AW/SO"me M5
11-06-2017, 08:09 AM | #28 |
Rep 573
msabiha2003
22 X3m
10 e90 335i 610whp 13 M5, 11.0@131 Fabworx DP,Precision Tune 650whp+ 11 E92 335xi 12.5@113MPH,362whp/438wtq GONE http://www.youtube.com/c/jairomvp Instagram:Jairomvp |
11-07-2017, 11:24 AM | #29 |
Rep 2,039
If I had the time to make one and sell it to our community I would... No ///M tax either!
jairomvp182522.50 |
11-13-2017, 08:38 PM | #31 |
Rep 35
Drives: 2014 BMW M5 CP
I been looking into making one myself, it shouldn't be too difficult, its a matter of hoses and some fittings, i will be interested if Allmotor made one , if not then Ill make one , and i know couple of friends also waiting on me to make one.
jairomvp182522.50 |
01-19-2018, 08:46 AM | #34 |
Rep 204
Did you figure out something on that catch can. I have been looking at routing on my M6 and researching catch cans. Just so many options out there. Are you thinking clear tubing at first to see if flow is actually reaching the catch can. I had to do it that way on the ZR1 at first to make sure my lengths and positioning of the catch can didn't deteriorate flow volume. Just thought you might have gone through the test and tune stage and save me some trouble. Thanks. By the way, lover your build.
03-07-2018, 11:26 PM | #37 |
Rep 1,124
Soliciting opinions for this can https://addw1.com/shop?olsPage=produ...l-catch-can-v1
03-08-2018, 09:51 AM | #38 |
Rep 349
Drives: M5 Competition Package
ECS Tuning and Turner Motorsports have catch cans for our car
07-30-2018, 09:05 AM | #41 |
Big girls don't cry.
127
Rep 506
A few options have been mentioned earlier to be in process, I'm subscribing to see if anyone has finished development of a set.
07-30-2018, 10:46 AM | #42 |
Rep 1,124
ASR is updating their oil catch can/air intake system. It should be available sometime this month
?When you have fast cars and bad luck, it's a lot easier to handle than having slow cars and bad luck.?
Kevin Harvick |
09-06-2018, 06:33 AM | #43 |
Rep 172
Drives: BMW M4
Hey Guys,
my M5 is suffering under a lot oil blow-by. Oil consumption is around 1L per 900-1500 KM and sometimes i have a huge big blue cloud behind me. That's why I took the trouble to design a suitable oil catch can. It will be a direct plug and play solution. Here you can see my breather adapter for the original Mahle-Pipe. From there we go by Dash10 to a 4Port Catch Can and then back to the stock inlet. Price will be around 399 USD, iŽll keep you updated. |
09-06-2018, 06:47 AM | #44 |
Perennial PFC
348
Rep 1,277
[QUOTE=Maltman;23687753 It will be a direct plug and play solution.[/QUOTE]
Looks good. That's two inlet and two outlet to accommodate both valve covers? Do you have dimensions of the catch can? Pictures installed on your M5 will be great to see when the project is finished. Is there a drain outlet for the catch can? Any cut away diagrams of the can to show us the baffling? |
