04-20-2017, 04:36 PM | #1 |
Rep 144
Aquamist & AWRON Installation
All,
The next phase of the build began yesterday. As the title states, we are installing a custom Aquamist system, assembled by Raz of RK Autowerks (complete with bespoke AN jet and pump adapter fittings, RK charge pipes, steel braided nylon lines; there shall not be component failure and subsequent conflagration ) and the AWRON digital gauge cluster. The Aquamist gauge will be installed in the mini-glove compartment to the left of the driver's knee. We will also load a more aggressive BPM Stage-II tune to take full advantage of the methanol injection system. As for the injection fluid, to further reduce the already diminished chance of catastrophic failure, I will use Boost Juice. While I have read that the coloring leaves a residue that could potentially spoil injectors, no such evidence to date has been presented; and worst case scenario, upon injector failure, I would simply purchase new ones. The trade off between component failure (here, injectors) and a vehicle fire is an easy one to make. Once the job is done, I will post additional images. Other planned modifications include map sensors, axles and a reinforced drive line. Should be well north of 800 whp in the very near future, without a "stacked" setup; I've never liked the piggy back tuning modules - another subject for another day as I do not wish to incite fanboys (or fan girls for that matter). Stay tuned!
2013 F10 M5 Singapore Grey | BPM Stage-II Tune | SSP Spec-R clutch-pack| RPI DPs | RPI GTM | RK Intake | Custom Aquamist WMI system | KW V3 coilovers | Dinan Sway Bars | RW Diffsuer | RW Front Spoiler | IND Trim | HRE s101s | Passport 9500ci | AWRON digital gauge cluster
AND: e92 M3, e70 x5, 997.1 GT3, F15 x5M, e34 M5, 80-series LC |
04-20-2017, 04:52 PM | #2 |
Rep 7,886
Cool man. Also, you can/should run pure distilled water in your injection setup from time to time to help the injectors clean. The distilled water will even give you a power bump too.
I hope you built up the transmission. The DCT doesn't like so much torque. My upgraded cooling system for my DCT has worked wonders for keeping the DCT temps under control. Good luck and post more pix when you can.
04-20-2017, 05:10 PM | #3 |
Rep 1,123
very nice, my car is in the process of getting a bms meth kit running with a dme tuning tune and jb4/bcm. Can you quote me pricing on the cf charge pipes please.
2018 F90 BMW M5 Marina Bay Blue
2012 F10 BMW M5 Imperial Blue 2006 E60 BMW M5 Indianapolis Red 2006 E65 BMW 750i Titanium Silver 2001 E39 BMW 530i Orient Blue |
04-20-2017, 05:12 PM | #4 |
1092
Rep 1,968
Looks very clean, but also very bold to run lines right above the hottest part of the engine.... These are steel-braided lines but have you verified the temp range?
Boiling point of methanol at 760mm HG is 148.3F. 800whp+ is an interesting target without independent boost control. Last edited by allmotor_2000; 04-20-2017 at 05:27 PM.. |
gary_F10M51.50 |
04-20-2017, 05:32 PM | #5 | |
Rep 294
04-20-2017, 05:51 PM | #6 | |
Rep 144
04-20-2017, 05:53 PM | #7 |
Rep 144
We will dyno post the installation of the custom Stage-II tune; and indeed, I will post the results.
04-20-2017, 05:55 PM | #8 |
Rep 144
PM Raz at Rk Autowerks. Great guy, exceptionally knowledgeable. He is an actual Engineer, which is a rarity in the aftermarket.
04-20-2017, 05:57 PM | #9 | |
Rep 144
04-20-2017, 06:28 PM | #10 |
Rep 881
Very nice! I have those RK CF charge pipes too, but may not end up using them as I've been thinking of plumbing the water/meth bung after the ICs instead of on the charge pipes. The Aquamist I may pick up from Raza also, but been waiting on the BMS stealth tank....
2014 "AW/SO"me M5
04-20-2017, 07:11 PM | #11 |
Rep 3,205
Looks like an awesome project. Subscribed!
04-20-2017, 07:22 PM | #12 | |
1092
Rep 1,968
Everybody has tricks... some work, some don't |
04-20-2017, 07:31 PM | #13 |
Rep 120
some of you dudes are crazy!!! One of these days I'll delete my charcoal filters
2013 BMW M5 - B&O Sound - Piano Black trim - 2 toned grey/black interior.
2016 M3 - Fully Loaded - GF's car Grave Yard - 2014 BMW 640i - 2007 BMW 335i - 2006 BMW M5 - 2003 Infinti G35 - 2002 BMW 740i - 2002 CBR 954r - 2000 BMW 540i - 2000 BMW 328i |
04-20-2017, 07:55 PM | #14 | ||
Rep 144
Thanks! One of several in progress. My wife nearly waterboarded me when I informed her of my 3.9 liter engine build on the GT3. I attempted to convey that the several projects in play are part of an elaborate design of experiments. Suffice it to say I was unsuccessful Quote:
That's how it starts...
04-21-2017, 08:05 PM | #17 |
Rep 144
Progress
All,
Progress pics from the installation; allmotor_2000, you will note the "T" orientation of the steel braided lines around the charge pipes. I am keen to see how accurately the AWRON gauge derives power estimates once the system is fully installed, compared to a dyno and adjusted for mechanical losses. Fun indeed.
04-22-2017, 12:11 AM | #18 |
Rep 788
Before you were water boarded by the wife, who's 3.9 build are you going with, Sharkies, Jamies or Cargraphic etc? Will make an awesome GT3!
As for boost juice, it is your choice but you are not gaining anything over distille wate and poor methanol (99% for cleaning etc) run at a mix of 50/50, its chearer than boost juice. Plus Boost juice doesn't have any 'non-flamable' properties over a home mix of water/meth and they add red dye which has been seen to gum up and then break the throttle bodies (not sure where you read about injectors?) Do a search on this forum for some photos of red gummed up and brroken throttle bodies. Your in good hands with Raz and will be interesting to see this project progress. |
04-22-2017, 10:48 AM | #20 | |
Rep 144
04-22-2017, 12:17 PM | #21 |
Rep 881
Nice! Looks like the 10L tanks sold by Howerton, which means the pump is housed within the enclosure....clean.
2014 "AW/SO"me M5
04-24-2017, 07:39 PM | #22 |
Rep 144
Thanks!
