08-13-2020, 07:25 PM | #1 |
Rep 541
2016 M5: 0w40 or 0w30
Hi all,
I have a 2016 M5 and the manual states to only use 0w40 BMW Longlife-01 / FE. As an alternative, 0w-30 may be used. I live in Northern California (hottest ~105f, coldest ~30f) So far, I see that Motul 8100 X-MAX 0W40 looks like a good option. Anyone else have any input on other brands? What about filters? Why are different years of M5's allowing 5w40 as well but not 2016? Thanks, Raz |
08-14-2020, 06:45 AM | #2 | |
Rep 606
I've always been a fan of Hengst brand filters. Never had an issue with them. They are made in Germany. You can't go wrong with an OE filter, either. I don't think they're overly expensive? I don't recall hearing that 5w-40 or even 5w-30 was ever written in the owners manual. Many times you will see 5w-30 recommended online as it is the "twinpower turbo" whatever brand from BMW. That oil is actually for the inline 6 turbo engines IMO. Sure you can run a 5w oil in the S63, I just don't think it's a good idea on a stock bottom end unless your temperatures on cold start are routinely over 90-100F during the entire oil change interval. |
08-14-2020, 08:04 PM | #3 | ||
Rep 541
08-15-2020, 08:23 AM | #4 |
Rep 606
The only time you should worry about LL01/LL04 ratings/certification is if you're running the OCI to the BMW recommended mileages. In this case, like 10,000? I think is the current recommendation. If you change the oil at a shorter interval, say 5,000 miles, then those certifications don't mean anything.
08-15-2020, 09:17 AM | #5 | |
Rep 543
08-23-2020, 08:56 PM | #8 |
Rep 541
I've decided on Mobil 1 0w-40 with a Mahle filter. Plan is to change every 4-5k miles. Should I keep it around 4k or is 5k good enough?
Any of you recommend a magnetic drain plug? I also bought a Weistec oil filter cap (w/ drain plug) to make changing the filter less messy. |
08-24-2020, 07:07 AM | #9 | |
Rep 606
08-24-2020, 10:14 AM | #10 | ||
Rep 127
08-25-2020, 11:08 AM | #11 | |
Rep 73
danielgmanm691.50 |
08-26-2020, 08:04 PM | #12 |
Rep 8
SpeedProtocol382.50 |
09-12-2020, 06:47 PM | #13 |
Rep 11,891
When I had my S65B40 V8 M3, I used Castrol TWS 10-60. For a large part of ownership, I was using M1 0-40 Euro LL-01. When BMW moved to the Pennzoil supplied blue bottles, I switched back the BMW TwinPower 10-60. That's for the NA V8 motor.
On my S63B44 M6, I've used the BMW 5-30 oil up until last year, when it was discontinued for the 0-30. My OCI is about 5k. Blackstone shows similar results for both 5-30 and 0-30 TwinPower Turbo oils. I like the 0 spec oils as it's easier on cold starts and short distance driving that I sometimes do. But I'd like a thicker oil that shears at a heavier weight when the engine is running at operating temps around 220-240 degrees. I'm surprised to see people still using M1 0-40. I'm tempted to go back to M1 again.
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
danielgmanm691.50 |
09-12-2020, 10:58 PM | #14 | |
Rep 541
Smooth starts and very smooth throughout the rev range. I plan to change it every 3-4K miles since it's so cheap compared to other options. |
09-15-2020, 08:32 AM | #15 |
Rep 19,974
Mobil 1 0W40 long life was recently recommended by BMW then taken off their ok to use list.
See no reason not to use it if there is nothing better available in your area. I use a Bosch oil filter, it has an extra guaze surround on top to trap any foreign particles which the M or Mahle ones haven't got. |
09-22-2020, 09:27 AM | #16 | |
Rep 344
Drives: M5 Competition Package
https://www.boschautoparts.com/en/auto |
09-22-2020, 10:54 AM | #17 |
Rep 19,974
^ P7158 Bosch. only fit 560,575,and 600hp M5 F10.
Compatible with Mahle OX353/7DECO and Mann HU8007z. Bought two from carpartsinmotion. online UK. |
10-16-2020, 12:42 AM | #18 |
Rep 541
Quick 1500 mile update on M1 0w40.
Burned about 0.8qt. Pretty normal driving, 90% of the time under 3.5k rpm. 60/40 highway:street. A few pulls here and there. Some to 140+ mph and one to 160+ mph. Overall car seems super happy with the oil. |
10-17-2020, 06:59 AM | #19 | |
Rep 606
My consumption is similar to yours, I think it's mostly just a coincidence that we're running the same brand/spec oil. |
M5_Raz524.50 |
02-05-2022, 11:11 AM | #20 |
Rep 541
Another update. Put about 15,000 miles while running Mobil 1 0w40 exclusively. I change it at about ~4,000 miles. The car runs very well and strong.
Since getting the catless downpipes, you can really see a lot of oil being burned. Still the same burn rate at about 1 quart per 1,000-1,500 miles, depending on how it's driven. I bought a magnetic drain plug and installed it at my last change. Drove about 3,000 miles with it already and will soon see if it makes a difference. |
02-05-2022, 11:06 PM | #21 |
Rep 1,250
At some point BMW discontinued 5w30 and our car received recommended 0w30. Since then 5w30 is back. I am in norcal and have been running exclusively 5w30 from BMW , one of the reasons is the this oil has really low NOACK. If you don't know what NOACK is, "The Noack volatility of an oil is defined as the weight loss of the oil when it is held under isothermal conditions at 250 °C for a period of up to one hour, depending on result collected from the reference material, under a constant flow of nitrogen."
So even tho you might use good brand synthetic oil, if the NOACK is high you might be burning more oil. |
02-06-2022, 11:59 AM | #22 |
Rep 541
It's okay for turbo engines to burn some oil. If anything it helps since I always keep up with it and it has fresher oil.
But why do you use an oil weight that's not recommended? My manual calls for 0w40 and 0w30 as an alternative. |
