Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > M5 versus...
      05-04-2024, 11:14 AM   #1
ghanii
ghanii's Avatar
14
Drives: bmw f10 m5
hello everyone today I'm showing you my dyno number from my most recent run i hope this helps you guys be able to see when your car is in terms of mods and to see the potential of getting a ots tune from bootmod3 because i searched everywhere any could not find any whp numbers.
Mods
-vrsf cattless down pipes
-gamma project front mount intakes
-ngk 2 step colder plugs gapped to 0.20mm
-BM3 ots stage 2 e30 tune aggressive burbles
-XHP STAGE 3 transmission tune at 20bar of pressure
link to video-https://youtu.be/IDT3ts15EP0?si=rXZlMH3ieQTNs-Do
1320racer157.50
KurtsM5218.50
      05-15-2024, 10:44 PM   #2
Boosted M5
Drives: F10 m5
Great numbers! I got mid 600 but I have no intakes and I used 100 oct. MP flash tune stage 2 with gutted oem cats. Let me know how your clutches handle.
ghanii14.00
KurtsM5218.50
      05-15-2024, 10:58 PM   #3
ghanii
ghanii's Avatar
14
Drives: bmw f10 m5
I’ve put about 10,000 miles with this tune on and so far the clutches have held up great I would recommend if you don’t have it to get an XHP stage 3 transmission tune because it does definitely help the clutch pack Stay alive longer because of the increase pressure in the clutch lines to help prevent clutch slip.
      05-16-2024, 04:16 PM   #4
Boosted M5
Drives: F10 m5
No way! I didn’t know that would help. Torque on mine is 673 so definitely always thinking about when the clutches will start to complain. Just when I thought I was done modify the car 🤦🏻‍♂️.
ghanii14.00
      06-18-2024, 12:51 PM   #5
1320racer
1320racer's Avatar
158
Drives: 2013 BMW F10 M5
WHP OR calculated crank HP
Looks great! Sounds great!
Was this dyno run in 4th or 5th gear?
The dyno screen indicated (HP), so is this calculated HP at the crank? If so, did they use a 17% drivetrain loss?
Or was that crazy number at the wheels (WHP) A.K.A. — Wheel Horse Power?
Past: 2002 Jeep Grand Cherokee, 2014 BMW 550i MSport, 2005 Jaguar S-Type R, 2000 BMW 540i, 1997 BMW 540i, 1997 WS6 Pontiac Firebird, 1992 Eagle Talon TSI
KurtsM5218.50
      07-27-2024, 09:44 PM   #6
B58
B58's Avatar
605
Drives: Junk
Something I would like to know as well.
      07-29-2024, 09:19 AM   #7
KurtsM5
2013 F10 M5  [8.80]
I'm willing to bet that's at the wheel. I don't know of a dyno that can guesstimate crank hp.
      07-29-2024, 09:45 AM   #8
ghanii
ghanii's Avatar
14
Drives: bmw f10 m5
1320racer KurtsM5 B58
Sorry for the late reply everybody to answer those questions. All those numbers were at the Wheel. The car made consistently 703 to the wheel and 661 foot pounds of torque as of which gear they used I honestly couldn’t tell you, but I think they did a couple runs and forth and a couple and fifth and the numbers came out to just about the same.
B58605.00
      07-29-2024, 01:46 PM   #9
B58
B58's Avatar
605
Drives: Junk
How’s your rail pressure holding up with the stock high pressure pumps and 30% ethanol?
