04-30-2023, 09:47 AM | #1 |
Rep 109
Idrive gremlins
Can anyone help. I’ve just changed my battery and I’ve lost HUD, access to enter time and a few other idrive settings. I’ve tried disconnecting the battery again and now have the SOS call issue. There’s no driving issues and operates as before but the electrics are driving me nuts. I’ve cleared all codes via BimmerLink but still no help.
Any ideas |
05-02-2023, 12:46 AM | #2 | |
Rep 280
05-07-2023, 11:09 AM | #3 |
Rep 7,488
The only reason for coding a new battery is if you change the type or specs of the battery. A new battery does need to be registered, though…which is a different procedure than coding.
Also, I’m confused. The OP posts on an F10 M5 forum….doesn’t mention what vehicle they are referring to…and when you look at the car info below their avatar…it lists a different BMW platform (an F30 3 series). So was the new battery registered? Was the new battery coded if different spec than the original? Did you turn the HUD back on using the button to turn it on (in case the battery replacement turned it off)? Can the OP post any pics of the issues with iDrive and an inability to reset the clock? You probably need to reset your sunroof, too…a loss of electrical power usually make it go wonky. Hopefully we’ll get an update…or will this thread get ghosted.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
05-13-2023, 02:36 PM | #4 |
Rep 109
I got to the bottom of the issue. The green cable that goes from the idrive unit to hud it’s a bright red light had become loose from the plastic coupler. A dab of super glue and all issues gone and we are back to normal 👍
Beast27358.00 |
