      03-01-2020, 10:58 AM   #1
pleong
Drives: F10 M5 & E36 M3
Suggestions to get these to fit?
I gave MVForged my name and model to build these wheels but unfortunately it's giving me a lot of issues.
The front poke a bit but I think I can make it work.
The tears are what's giving me the most issues.
I have to use 5mm spacers to get them to clear the rear calipers.
And with the spacer it pokes out even more now. Any suggestions on how to get them flush?
They didn't give me ET specs but here's what I know.
F 20x9.5 275/30/20
R 20x11 305/30/20
      03-01-2020, 12:43 PM   #2
Hum5
Drives: M5 f10
A stretch tyres should do the trick also lowering the car as much as you can will make the fitment much better.
For the tyres size i recommend
235/35/20 F
275/30/20 R
This is what im running on my wheels
      03-01-2020, 07:16 PM   #3
jasamja
Drives: 2014 BMW M5
wow someone messed up those Offsets pretty bad, i mean a 11" wheel is nothing extreme what is the ET on it seems to be around 20 based on the pictures you posted
      03-01-2020, 07:22 PM   #4
pleong
Agreed, but they didn't provide the offset. I'm thinking they used M6 GC specs
M5Rick60060.50
      03-01-2020, 11:27 PM   #5
HXS
Licensed Drug Dealer
HXS's Avatar
I would return the rims and get my money back. It’s their fault they didn’t provide you wheels with the correct offsets even though you gave them the info.
At the least they should change out the outer barrel to a half inch smaller, so the rears would be 10.5 instead of 11. Your 305’s should fit on the 10.5 as well
RG60411.00
pleong17.50
      03-01-2020, 11:49 PM   #6
RG604
Drives: f10 m5
yeah they fucked up it's on them to figure out not you
IG: RacingGreed
pleong17.50
