      07-03-2020, 09:06 AM   #1
bquicksilver
bquicksilver's Avatar
Drives: 2014 F10 - Alpine White CP
305 MP4S Rubbing
Anyone else experience rubbing going to 305/30/20 MP4S tires? I have a 12mm spacer out back and going from OEM 295/30/20 I'm getting a little rubbing.
Obvious answer is a smaller spacer, but i'm curious if others have ran into some rubbing with these tires. The traction is great, but they're a wide 305 for sure.
      07-03-2020, 03:34 PM   #2
Barry_S
Barry_S's Avatar
Drives: 2015 M5 F10
2015 BMW F10 M5  [0.00]
2018 BMW F15 X5  [0.00]
I have those tires on mine, but with a 5mm spacer. No rubbing.
I'm also lowered on KW HAS.
      07-04-2020, 03:32 PM   #3
JtheW
Drives: 22 m850gc
I’m also lowered on KW HAS with a 5mm spacer. No rubbing at all. That 12mm is too big.
22 M850i gran coupe
      07-07-2020, 01:48 PM   #4
707M5
Drives: 2013 Bmw m5
I had 315s in the rear with a 5mm spacer. No rubbing. Lowered on H&R springs
      07-07-2020, 11:04 PM   #5
Barry_S
Barry_S's Avatar
Drives: 2015 M5 F10
Which tire did you use for the 315's?
      07-07-2020, 11:06 PM   #6
707M5
Drives: 2013 Bmw m5
MP4S
      07-08-2020, 05:06 PM   #7
Barry_S
Barry_S's Avatar
Drives: 2015 M5 F10
MP4S
Interesting. I would have thought that wouldn't fit. Mine is very tight with the 305. What rim are you using?
      07-08-2020, 05:51 PM   #8
bquicksilver
Thanks for all the replies. I grabbed a 10mm spacer, will report back if it's still rubbing.
      07-08-2020, 05:54 PM   #9
Gel2al2d
Drives: '93 Toyota MR2, '14 BMW M5
I was on a stock 343 with 10mm spacer running R888R 315s. fitment was spot on
      07-08-2020, 05:55 PM   #10
bquicksilver
Comp height or non-comp?
      07-08-2020, 06:00 PM   #11
Gel2al2d
oh sorry mine is comp but i replaced it was KW HAS. i had it sitting right on top of the tire
      07-08-2020, 06:24 PM   #12
bquicksilver
Wonder if the KW guys are running enough extra negative camber to tuck in a little better than stock.
      07-08-2020, 06:41 PM   #13
Barry_S
Barry_S's Avatar
Drives: 2015 M5 F10
No extra camber on mine. Fits nicely with the 5mm and the KW HAS.
      07-08-2020, 06:45 PM   #14
707M5
Drives: 2013 Bmw m5
MP4S
The stock 343 wheels.
      07-08-2020, 07:05 PM   #15
707M5
Drives: 2013 Bmw m5
MP4S
Currently running 315s on 11" wide wheels with +32 offset and fits perfect
      07-08-2020, 07:29 PM   #16
Barry_S
Barry_S's Avatar
Drives: 2015 M5 F10
MP4S
You were able to put a 315 on the stock 343 rim? I wouldn't think that would be safe. I think the 315 calls for an 11" rim as per your current set up.
      07-08-2020, 07:39 PM   #17
707M5
Drives: 2013 Bmw m5
MP4S
It fits. Lots of people run 315s on the stock wheels.
      07-12-2020, 10:07 AM   #18
Doctor_X
2015 BMW M5 CP  [0.00]
2022 BMW M5 CS  [0.00]
I’m running the same tire, 10mm spacer, lowered on KW HAS. Rubs very lightly on plastic inner fender only on big deep bumps at high speeds.
      07-12-2020, 10:48 PM   #19
bquicksilver
Went from 12mm to 10mm, now same as the poster above i only rub on the plastic liner on large undulations at speed. At 12mm I was cutting into the tire from rubbing the metal fender. I bet 8mm would be a no-rub situation.
      07-15-2020, 06:39 AM   #20
M5Dan
M5Dan's Avatar
Drives: M5 Competition Package
2019 BMW X7   [0.00]
2016 BMW M5  [10.00]
How about running a 305/30/20 on stock 343m wheels in the rear with no spacers will it rub without spacers or do you need spacers?
      07-15-2020, 08:29 AM   #21
1320racer
1320racer's Avatar
135
Drives: 2013 BMW F10 M5
This has been my set up for the rear, stock suspension, without spacers, and I have never experienced rubbing.
  • MPSS, 295/30/20 (stock size)
  • MPS4S, 305/30/20 (visually, appeared to be my widest tire so far)
  • Bridgestone RE980, 305/30/20 (visually, appears narrower than same size MPS4S | Bridgestones at a 315 mm width would likely fit) but as suggested by others—it might be pushing it too far
Past: 2002 Jeep Grand Cherokee, 2014 BMW 550i MSport, 2005 Jaguar S-Type R, 2000 BMW 540i, 1997 BMW 540i, 1997 WS6 Pontiac Firebird, 1992 Eagle Talon TSI
      07-15-2020, 12:39 PM   #22
707M5
Drives: 2013 Bmw m5
I ran 315s on stock wheels with 5mm spacer. No rubbing at all
