12-10-2018, 03:03 PM | #2 |
Rep 1,326
If you can get at least 6 turns in with your standard wheel bolts you should be ok. Personally I would go with extended bolts for peace of mind.
2014 Frozen Black F10 M5 | Agency Power HFC Downpipes | Custom Open Flash Stage 2 Tune | KW HAS kit | 3D Design Lip | 3D Design Skirts | 3D Design Spoiler | IND Front & Rear Reflectors | IND M5 Badge | M Performance Steering Wheel | M Performance CF Shift Knob | Pedal Haus Pedals & Paddles | Turner Exhaust |
12-10-2018, 04:34 PM | #3 |
Rep 19,960
02-05-2019, 09:16 PM | #4 |
Rep 1,073
Wondering how the 5mm looked on your car?
03-02-2019, 07:05 AM | #7 |
Rep 1,073
Buy spacers from BMS
They come with bolts and I've had perfect results on last 2 cars with them
09-03-2020, 05:14 AM | #8 | |
Rep 39
I'm going the 305 tyres route and was thinking I might space them out, just a little bit. |
09-03-2020, 01:13 PM | #9 | |
Rep 19,960
17mm Bolts are by trs-uk. 10xM14x1.25, 33mm thread tapered wheel bolts. Good luck! *can use the locking wheel nuts if you wish, its over six turns to tighten. Last edited by M5Rick; 09-03-2020 at 01:28 PM.. |
Guy M516.50 |
09-03-2020, 01:52 PM | #10 | |
Rep 39
I'm going to hold off purchasing some for the moment, since I posted this morning I have decided to order the NO (Porsche version) of the PS4's which are supposed to have .4 inch (10mm) wider tread than the standard 305's while keeping the same actual tyre section width. I'll fit them first and see what they look like. Thanks for the info, much appreciated! Last edited by Guy M5; 09-03-2020 at 02:12 PM.. |
M5Rick61805.50 |
09-13-2020, 04:49 AM | #12 | |
Rep 39
The Porsche version of the 305 P4s have a tread width of 320, too big! I have now fitted standard 305 P4's with no spacer and I think I'll leave it at that. Thanks for all the help. |
M5Rick61805.50 |
09-13-2020, 12:20 PM | #15 |
Rep 19,960
Yeah,I'd stick to the standard,those Porsche ones are extra wide tread for the engine over wheels traction of a 911.
09-13-2020, 12:25 PM | #16 | |
Rep 19,960
Mine are just on the back wheels,I have none on the front. 15mm spacers is way too much I think and as your having h&r lowered it may catch more. Best bet is to first get the springs fitted first then go from there...I'd say 10mm max. Good luck! |
J11SEK268.00 |
09-13-2020, 01:21 PM | #17 | ||
Rep 226
M5Rick61805.50 |
09-13-2020, 02:25 PM | #18 |
Rep 19,960
It's on the thread below.
10-26-2020, 12:43 PM | #19 |
Rep 19,960
Bolts should be 33mm for 5mm spacers, standard are 28mm.
