      08-15-2018, 11:31 PM   #1
YanoM5
Drives: 2018 Individual Nardo M5
Bootmod3 Tune Questions
Hello M5/Bootmod3 owners. I’m new to the M5 platform and just purchased a BM3 tune. A couple questions if i may...
1. I’ve read on forums I need a battery charger to flash? This is new as when I’ve done a flash on my previous cars GT-R and S4 I didn’t need a battery charger.
2. I live in Washington and we have 92 octane. Would it be safe to run the 93 OTS tune instead of 91. If I do chance it with the 93 OTS tune, is there a knock safety feature that cuts boost or adjust timing?
Thanks in advance.
      08-16-2018, 03:36 AM   #2
M5BMW
Drives: M5 F10
1. If your battery is good then you don't need a charger.
2. DO NOT use an octane rating which is less than recommended. If anything, always use a higher than recommended octane. This is especially important when running fuel from the US of A.
      08-16-2018, 03:53 AM   #3
OneExtra
OneExtra's Avatar
Drives: None
Personally I wouldn't risk not using a charger, everytime I have spoken or seen a car mapped for the first time they use a charger, its not worth the risk.
Just make sure it flows at 20a when on charge as this is about how much it uses when uploading
      08-16-2018, 06:04 AM   #4
Mr. M6
Mr. M6's Avatar
149
Drives: M6
2014 BMW M6 F06  [9.25]
use battery charger for first time because it will unlock the DME first...
for octane get OTS 91 octane and use 92 octane... dont do 93 octane and you have 92... or boost your octane up with anything in the market
good luck
      08-16-2018, 05:56 PM   #5
YanoM5
Okay. It sounds like using 91 is the way to go. I’m just sad that I’m leaving so much power on the table by not going 93.
      08-22-2018, 01:50 PM   #6
ssgm1x
ssgm1x's Avatar
Drives: 2020 M340i & 2018 M3
i needed a battery charger cause my battery was like 3-4 years old....after replacing battery with a Brand new one i have not once used a charger. Have flashed over 50 times with Zero issues. If u have a new battery u r fine. If u have a battery that is over 3 years old u may need a charger........DME unlock takes 4-5 minutes. Map changing takes about 1.5 minutes....
2020 BMW M340ix Dravit Grey
2018 BMW M3 Alpine White
      08-22-2018, 02:43 PM   #7
OneExtra
OneExtra's Avatar
Drives: None
A friend used Open Flash for the first time and it took 45 mins from start to finish.
Battery charger always reccommended, not worth the risk.
      08-22-2018, 03:15 PM   #8
Pikey Motorsports
Pikey Motorsports's Avatar
Drives: M5
So I don’t need jb4?
      08-22-2018, 03:56 PM   #9
schnell1982
Drives: FAST
If your voltage drops or something happens electrically wise during programming, you will regret that you didn't use a charger.
The Bootmod program will note to make sure battery voltage is stable.
It is 100% recommended for the initial read out-programming
Software updates occur within 1-2 minutes and do not require a voltage supply.
      08-22-2018, 03:56 PM   #10
schnell1982
Drives: FAST
Throw your JB4 into the trash
Its an item of the past and their support is garbage
Lots of current issues with their recent units
      08-22-2018, 05:44 PM   #11
Pikey Motorsports
Drives: M5
I don’t have jb4.. I thought it was needed to control meth
      08-22-2018, 11:06 PM   #12
YanoM5
Thanks for the info guys. I do have a battery charger. Any further comments on my 91 or 93 octane question?
      08-22-2018, 11:07 PM   #13
YanoM5
Dumb Question: When flashing hookup the charger to the battery in the rear right? I though I read somewhere, there’s an easier option on the front?
      08-23-2018, 04:37 AM   #14
dsmclark
Drives: Cayman GT4 Clubsport
run the 91 map and I have always attached the charger to the charge points under the hood! saves taking the floor up in the back
      08-23-2018, 08:01 AM   #15
YanoM5
Is it pretty easy to find in the hood?
      08-23-2018, 08:16 AM   #16
dsmclark
Yeah there is a red cover on the positive terminal and then there is a metal bar for the negative just behind the headlight. its on the drivers side (right) in the UK not sure if its on the left in America
Edit: looks like its the same
OneExtra810.50
      08-23-2018, 11:26 PM   #17
YanoM5
I figured it out. But thank you so much!
      10-24-2018, 09:07 PM   #18
irishbimmer
Drives: Silverstone M6 CP, Bulldozer,
For a 91 octane tune on a 2015 competition package- what are the estimated gains at the flywheel for hp and torque from stock?
thx
      11-01-2018, 02:51 PM   #19
Lightfytr
Drives: 2017 750ix 2014 M5 Competition
I just did the Stage 1 93 Octane and its insane.
