      03-27-2018, 02:43 PM   #1
k3silk
k3silk's Avatar
Drives: 11 M3 & 14 M5
Plastic M style rear diffuser where to buy?
http://f10.m5post.com/forums/attachm...1&d=1474165812
      03-27-2018, 02:47 PM   #2
VoytekM5
Drives: 2013 M5
search ebay... tons of options.
      03-27-2018, 03:02 PM   #3
chrisho68
Drives: AW/SO F10 M5
Any reason you wouldn't consider the OEM M-performance CF diffuser? Fitment is perfect. I wouldn't be worried about damaging it unless you ran over something really big and it hit at just the right angle. Sure maybe a little damage from small debris might happen but the CF just looks too good to pass up
[IMG][/IMG]
      03-27-2018, 04:41 PM   #4
k3silk
k3silk's Avatar
I don't want to bring carbon fiber on the outside of my M5 I have it on my M3 but like having that part abs black. EAS made one that was cheap and abs black plastic. plus 1200 for a little part is just not worth the cost to me.
      03-27-2018, 04:42 PM   #5
k3silk
k3silk's Avatar
I did and didn't fine the one I posted thats why I asked here because a member had it on his car.... but if you find one please make a link...
      03-30-2018, 06:39 PM   #6
msq123
Drives: BMW M5 F10 2014
Check out alibaba. You will find lot of options there. Of course, fitment could be an issue but nothing that some 3m tape and few small drills can't sort out.
      04-01-2018, 02:13 AM   #7
Jens Mariager
Drives: M5
Hi you have to remove the bumper then it's easier
      04-01-2018, 08:38 PM   #8
CHEFJAVF10
Drives: BMW F10 M5
[IMG][/IMG]
I'm about to purchase this m performance cf diffuser ... ?is it easy to put on urself?
      04-03-2018, 02:41 PM   #9
Charlie_Big_Potato
Drives: 2016 X5M
iND has the carbon fiber on sale right now. I might pick one up and wrap it. I also don't want carbon on the outside.
      04-03-2018, 08:54 PM   #10
chrisho68
Very easy to install. Only probably takes 15 minutes and some patience. There is a write up in the DIY forum: http://f10.m5post.com/forums/showthread.php?t=1205882
Just need a Torx T27 bit and a plastic trim remover. Just be patient with it when removing. The OEM CF piece slides in like butter. Good luck
      04-06-2018, 10:08 AM   #11
CHEFJAVF10
Drives: BMW F10 M5
Really how much is it cause bmw has it for 950 at the dealer
      04-06-2018, 12:32 PM   #12
Charlie_Big_Potato
Drives: 2016 X5M
$650 I believe.
      04-10-2018, 09:07 PM   #13
k3silk
k3silk's Avatar
$650 is not a bad price...
