      05-31-2017, 09:09 PM   #1
PetrolFumes
Drives: Raptor, GT3RS,E92 M3,X5M50i
305/30 tire on 343m wheels?
anyone running this size on the stock 343m wheels in the rear? I want to bump up for more traction with tune and downpipes
      05-31-2017, 11:55 PM   #2
apexlocator
Drives: 2014 M5
Yes, 305/30/20 99Y pzeros on stock 343m. Wont make much difference with a flash tune because the wtq increase is so significant, at least for pzeros. Others can chime in with 305 MPSS or MP4S....
2014 "AW/SO"me M5
Mission Performance/3.5 Bar
RK Autowerks/ CSF ICs
SSP Spec-R
KW V3/ Corsa Axle back
      06-01-2017, 06:34 AM   #3
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
@apexlocator is correct. The Pirelli Pzero 305/30/20 99Y will fit perfectly. My personal experience has been great with the setup, I did have better traction over the MPSS. Has to be 99y on the 305 to fit right.
Others have fitted the R888s which are a very sticky tire but very low tread wear and not a DD tire. It does have a slight bulge.
Here are some old pictures I had when I had my car and the 343M setup
      06-01-2017, 08:27 AM   #4
PetrolFumes
Nice
      06-01-2017, 09:03 AM   #5
KMORGSM5
KMORGSM5's Avatar
Drives: 14 CP M5
I'm running 305/30-20 MPSS and would def recommend doing it over the stock 295's. Technically it's to wide for a 10" rim, but I don't notice a difference in drivability other than better traction. Plus looks better I have spacers 12mm front, 10mm rear.
      06-01-2017, 10:28 AM   #6
PetrolFumes
Perfect fitment with the spacers
      02-08-2019, 03:24 PM   #7
SLOWER
SLOWER's Avatar
Drives: 2003 M3
What's the proper front tire if you upgrade to 305 rear?
      03-30-2019, 05:22 PM   #8
tampaturbom3
Drives: 2013 BMW M6 Coupe
Mich Pilot Cup 2’s. 305/30/20 no spacers and plenty of room inside and at the lip. I’ll likely try an even wider tire (315/30/20) next time if i can find one...
Tommy
2013 M6 Coupe- Tanzanite blue
      05-02-2019, 06:42 AM   #9
schrickm5
schrickm5's Avatar
Drives: 2013 M550d xdrive touring
Guys - has anyone checked the inside of the 305 tires you are running for wear due to touching suspension parts?
Obviously its too late once you know you have damaged it.....at speed.
How many are on a CP and spacers at the rears and running 305 or bigger (on 343's)?
2015 M5 CP Blue
[SIGPIC]
Previous Cars:- 2015 GTR > 2014 M5 CP > 2006 M6> 2007 M5 E61 > 2014 F31 328xi >2001 E39 530i > 1995 E34 M5 > 1999 Alpina B8 > 1992 E34 M5 >
      05-02-2019, 03:22 PM   #10
Clears it fine without spacers though I have 5mm spacers so the inside is in exactly the same position as if it was running 295's.
      05-02-2019, 07:36 PM   #11
carlitosgomesm5
same here running 305/35/20s with 5mm spacers. AutoCoutureMotoring said cleared fine.
      06-25-2019, 07:01 PM   #12
jt1k
jt1k's Avatar
Drives: M4
+ 1
2016 M4 Silverstone/Sahkir
      06-25-2019, 09:19 PM   #13
Newport Blue
Newport Blue's Avatar
Drives: 2014 M5 Competition Package
2015 M5 CP  [10.00]
CP on KW HAS with 305's and no rubbing on suspension with 10mm spacers.
2014 Competition Package/BPM Stage 1 Tune/KW HAS/10mm Front HR Spacers/12MM Rear HR Spacers/305x30x20 PS4S/Carbon Mirror Caps/Black Wrap Roof/ Soul Performance Exhaust/Vorsteiner Rear Diffuser/ 3D Carbon Fiber Front Lip/ RW Carbon Arkym Carbon Fiber Rear Spoiler/
      07-05-2019, 06:19 PM   #14
roscopeeco
Drives: 2016 BMW M5
Do you need longer factory bolts when running 10mm spacers on 343-295 size tires. How about 305s?
      07-05-2019, 08:39 PM   #15
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
the longer bolts are dictated by the spacer
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      02-08-2022, 07:19 PM   #16
Da_Meister_22
Da_Meister_22's Avatar
208
Drives: F10 M5 & F85 X5M
Hello guys, I have a question.
Can I go 315s on the rear and 285 on the front?
I'm looking for an aggressive rear look, and I see one of the best ways to achieve this is by fat rear tires lol
      02-10-2022, 09:06 AM   #17
Don't think you can get 315's in Michelin.
      02-10-2022, 06:35 PM   #18
M5_Raz
M5_Raz's Avatar
514
Drives: BMW M5
You can do 315 with Toyo r888r. However, if you do that, you might need to reinforce the rear end so it doesn't break stuff with all that grip.
      02-11-2022, 02:29 PM   #19
Getting a reinforced diff rear billet just for those Toyo's would make it quite an expensive tyre change
      02-22-2022, 05:51 AM   #20
Da_Meister_22
208
Ok, seems like best set up would be 305/30/20 Rear and 295/30/20 Front
AW F10 ///M5
AW F85 X5///M
BootMode3 STG 2///Project-Gamma Intakes///ActiveAutowerke DPs///Maxton-Design Body Kit
@MeisterAutosport @RatedMClub @RatedMRally
      03-08-2022, 01:16 PM   #21
707M5
Drives: 2013 Bmw m5
Yes you can.
      03-09-2022, 01:28 AM   #22
Bentham
Drives: M235i
Love your ride!
