Go Back   M5POST - BMW M5 Forum > M5 Classifieds > Members Classifieds
      03-13-2017, 02:58 PM   #1
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
FS: s63tu engine + Gaskets/Bearings/Timing Chain
BIMMERPOST / Classifieds
Asking Price:
USD 8,700.00
Or Best Offer
✓ Will Ship
Item Interest
Folks.
I am selling the long-block I had purchased for a rebuild. What I am including are:
1. s63tu long block assembly
- Includes the entire rotating assembly intact
- No manifolds, HPFP or anything that bolts on the outside
2. Cylinder Head Gasket Kit - OEM Part # 11122327854
- GetBMWParts price is $723
3. Short-block Gasket Kit - OEM Part # 11112250202
- GetBMWParts price is $256
4. Timing Chains x 2 - OEM Part # 11317605195 / 11317605193
GetBMWParts price is $90 each
5. Timing Chain Guide x 2 - OEM Part # 11317594909 / 11317594899
- GetBMWParts price is $38 each
6. Calico Coating Bearing Set (Rods, Crank, Main) by VAC Motorsports
- These are OEM bearings coated for high-temp / low friction
- These cost me $1250
Description:
All the gasket kits, timing chains, guides and bearings are NEW and UNOPENED from the condition I purchased them. I purchased the s63tu from a dealership that swapped the motor out for someone. It is off a 2014 M5 with 22K miles. The motor runs but has a ticking noise - presumably a rod/piston likely needs to be replaced as that's the typical failure mode on this motor. I never opened it up so can't say which cylinder per se. This is intended for a REBUILD.
These are my cost #'s. A running s63tu long-block is upwards of $12K and complete engines are easily $15-$17K as a comparison.
Motor will be on a pallet and all the parts boxes will be included in a single shipment. Shipping is NOT included but PM me and we can work something out if needed.
      03-14-2017, 03:54 PM   #2
allmotor_2000
1087
^bump
      03-24-2017, 10:22 AM   #3
allmotor_2000
1087
^bump - reduced to $8700
