F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Bad turbo
Extreme Powerhouse
      04-23-2024, 07:08 PM   #1
f30Nate
f30Nate's Avatar
Drives: 340i Bmw
Bad turbo
I just got a 6466 percision turbo I’m not sure if it’s bad or not can someone tell me if this looks normal or not?
      04-24-2024, 10:31 AM   #2
LA1Z24
Drives: 2014 435i M Sport
The impellar looks like it ate something at some point. The leading edge has a nick in it
      04-24-2024, 07:49 PM   #3
E36M3
Drives: 97 M3, '14 335i, '12 X3 35i
There is all kinds of erosion damage on the leading edges of the compressor blades along with the big pit on the one blade. This was clearly run without an air filter on the previous car and suffered for it. Pull the housing off and check for scoring around the scroll and wheel area along with radial and axial shaft play. I wouldn’t run this turbo as the large gouge at high compressor speeds/pressure ratios of higher boost can lead to crack origination at this point of damage and through cyclic fatigue can lead to a ruptured compressor impeller.
f30post
