      08-26-2015, 07:18 PM   #1
momos750
momos750's Avatar
143
Drives: 2015 M5, 2011 750Li
Spark Plugs
Howdy fellow Festers! Question for those of you that are running a full ecu tune or BMS with more boost.
Are you guys running colder plug ranges with the higher boost levels over stock?
Just curious since I have seen zero posts about changing plugs other than for normal maintenance.
Thanks for the replies! ?
      08-26-2015, 07:31 PM   #2
mstmng
Drives: M5 F10
my tuner suggested me to change plugs to f8* m3/4 plugs as they have smaller gap
      08-26-2015, 07:50 PM   #3
allmotor_2000
1092
Drives: 2018 RS3, 991 Turbo
I just re-gapped to 0.022" and I haven't seen any misfires yet at 27psi and all sorts of fuel combinations
      08-26-2015, 08:19 PM   #4
momos750
momos750's Avatar
143
Hey allmotor_2000 so you're still running the stock plug, just re-gapped?
      08-31-2015, 09:27 AM   #5
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
I don't have the experience to suggest another spark plug but after 5k miles running BMS, my plus weren't looking too great. Just had them changed out. Only 15k on the car when It was installed.
      08-31-2015, 10:51 AM   #6
momos750
momos750's Avatar
143
I've been reading that the piggy back's and tunes seem to shortening the life of a few components. Namely spark plugs and coils.
From experience on other forced induction motors I have always changed to colder plug ranges when increasing the boost. I'm wondering if the increased boost and heat are wearing out the plugs more quickly.
      08-31-2015, 03:47 PM   #7
13M5F10
13M5F10's Avatar
True, I have always changed my plugs in my Supercharged/Turbocharged cars but never had premature wear. The issue in are cars are due to various items like timing, knock, under boost... etc . Most piggys are just increasing boost without properly tuning the other parameters. I think with a proper tune, you shouldn't see plugs wearing the way they do on piggys.
This is just my opinion.
      09-02-2015, 07:46 PM   #8
allmotor_2000
1092
Running stock timing with lots of boost and poor fuel will shorten the plug life.
      09-06-2015, 10:59 PM   #9
Msizzle
Drives: 2013 M6 Coupe
what is the stock gap of the plugs? did you use colder plugs?
      09-07-2015, 08:31 AM   #10
Andym3100k
Singapore
110
Drives: 2014 M6 GC FULL HAMMAN WIDE BO
I think Rama is using stock plugs but gap it to 0.22".
      09-07-2015, 04:42 PM   #11
m5james
m5james's Avatar
Drives: '10 X5M Alpine White on Sakhir
Completely different engine, but nevertheless...in the Lightning/Harley world we're running NGK copper plugs with varying gaps and changing them every 10k or so once we're past like 10psi. They give great readings and don't hold heat like titanium or iridium. I'm sure BMW knew what they were doing when they picked the plugs they're using, but now what we're pushing well beyond that, factory spec plugs might be out the door.
http://www.lightningrodder.com/forum...ead.php?t=2986
      09-08-2015, 04:26 PM   #12
allmotor_2000
1092
Stock is 0.034. There may be colder options but haven't tried that yet. So far seems to hold 26-27psi + meth. Again I run slightly less timing than stock so not sure how this works for everybody else.
      09-08-2015, 04:27 PM   #13
allmotor_2000
1092
You forgot a decimal :-)
Too bad I couldn't see your car while in Spore. I am heading back today. Next time!
      09-08-2015, 04:39 PM   #14
Andym3100k
Singapore
110
Yup, just too bad. The car is in the workshop swapping larger turbos, tuning the dme & doing some additional ice tank for the Intercooler.
      09-08-2015, 05:04 PM   #15
momos750
momos750's Avatar
143
Do you run less timing to avoid detonation? Shouldn't you be able to run those pressures with meth ok? What octane fuel are you running?
