11-07-2017, 01:28 PM | #1 |
Rep 2,650
► Built-To-Order Suspension Kits Available at APEX Race Parts (JRZ, Hyperco, GC)
Built-To-Order Suspension Kits Available at APEX We know there's no one-size-fits-all for coilover kits. We also know that there's a difference between simply lowering your car, and actually improving its performance in a meaningful way. It is crucial that any coilover kit is built around a quality damper, which is why all of our kits are built around the JRZ RS Line. However, we all use our cars differently, so we offer the ability to customize a coilover kit using race-proven components to meet your specific goals and budget. Best of all, you can get it all from one place. Why buy from APEX? It's simple. We use better springs and camber plates, we custom-build kits to your specs, and best of all, everything is in stock and ready to ship from our Livermore, CA warehouse. Not to mention, we've priced our complete JRZ coilover kits below others that are selling them with lesser quality components. JRZ Suspension Engineering calls on over 60 years of experience in development and production of motorsport dampers. With numerous factors like track surfaces, weather conditions and tire compounds, the adjustability of JRZ dampers ensures you can utilize your car's full potential at all extreme ends of the spectrum. Ground Control has been building world-class street, track, and full road race suspension setups since the 1980s. They have designed and built setups for hundreds of different chassis and applications. From no-compromise racing camber plates to refined, comfortable street plates, Ground Control's engineering and attention to detail makes them our camber plate of choice for any street or race application. We chose Hyperco springs mainly because of their near-perfect (within 2-4%) linear rates. They're more resistant to bowing than most other brands of spring, and because of their highly developed design, the springs are able to maintain their original free length and rate throughout a near-infinite operational life. Visit our website to order Selecting The Right Suspension Kit All of our complete coilover kits include the following: 4x JRZ Dampers 2x Ground Control Front Camber/Caster Plates 4x Hyperco 2.25" ID Coilover Springs 2x JRZ Rear Ride Height Adjusters 4x JRZ Soft Bump Stops Optional Extras that can be added to your kit: 2x or 4x Hyperco 2.25" ID Helper Springs with Helper Spring Guides 2x Ground Control Rear Articulating Weight Jacks (replaces rear height adjusters) 2x Ground Control Rear Shock Mounts 1. JRZ RS ONE Single Adjustable Coilover Kit Single-adjustable dampers Preset compression setting Adjustable rebound settings (24 clicks) Ideal for the driver who wants a professional, adjustable, motorsport-proven damper without the higher price points of the RS TWO and RS PRO dampers. 2. JRZ RS TWO Double Adjustable Coilover Kit Double-adjustable dampers Adjustable compression settings (14 clicks) Adjustable rebound settings (24 clicks) Ideal for the semi-pro driver who wants to become more familiar with suspension tuning using a quality damper. 3. JRZ RS PRO Double Adjustable Coilover Kit Double-adjustable dampers with external reservoirs Adjustable compression settings (14 clicks) Adjustable rebound settings (24 clicks) Adjustable nitrogen gas pressure Quick-disconnect reservoir plumbing for front dampers (rear optional) Ideal for the pro racer who requires the precise adjustability that only external reservoirs can offer. Find Your Suspension Kit Suspension Kits Available For:
Questions about camber plates, suspension and wheel fitment? Click here to get a personalized fitment recommendation from one of our experts. Ordering and Contact Information
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers Last edited by ApexWheels; 11-14-2017 at 05:22 PM.. |
11-14-2017, 01:36 PM | #2 |
Rep 2,650
JRZ, Hyperco, and Ground Control - the coilover dream team.
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
01-12-2018, 03:33 PM | #3 |
Rep 6,723
We've done our homework and have selected only the highest-quality components to use in the suspension kits we offer. Best of all, we stock these parts in our own warehouse, so there is no need to order everything from a different supplier.
Choose your dampers. Choose your camber plates. Choose your spring rates. Give us a call or PM with any questions, we're happy to work with you to build the ideal setup for your application.
03-06-2018, 03:32 PM | #4 |
Rep 6,723
It's all in the details. Our helper spring adapters are designed to minimize stack height at all costs. Using a recessed mounting pad adds less than 1/4" to the overall height of the setup, while precisely matching the diameters of both springs and not allowing any play.
03-15-2018, 02:28 PM | #5 |
Rep 2,650
Distinct "clicks" and easy-to-reach adjustments are just another reason why we're so excited to offer JRZ dampers in our coilover kits.
04-26-2018, 02:53 PM | #6 |
Rep 2,650
Learn more about the JRZ RS-ONE damper in our blog article.
06-21-2018, 12:21 PM | #7 |
Rep 2,650
Learn more about the JRZ RS-TWO damper in our blog article.
07-11-2018, 11:15 AM | #9 |
Rep 2,650
Thanks for the post! Although not listed on our site currently, we do have RS-ONE/TWO/PRO kits available for the F10. Feel free to PM us with more info on your car and your goals and we'll be happy to put together a kit for you.
--Dylan
11-27-2018, 11:32 AM | #10 |
Rep 2,650
Here are a couple photos of the kits that were produced specifically for us in our last group buy:
04-18-2019, 02:46 PM | #11 |
Rep 2,650
We have many full coilover kits with Ground Control camber plates and Hyperco springs in stock and ready to ship today. You already have an incredibly balanced chassis, watch it come to life with an adjustable suspension that can keep up. Your favorite tracks as well as the roads you drive every day will be much more enjoyable. Get yours fast as we are the largest stocking distributor of BMW-specific JRZ suspensions in the United States.
