Go Back   M5POST - BMW M5 Forum > M5 Classifieds > Sponsors Classifieds
      12-03-2015, 10:31 AM   #1
sales@vivid
sales@vivid's Avatar
Drives: 2014 BMW M5 DCT
Vivid Racing ◄♦► VRTune ECU Flash/ Tuning Box/ OBDII flash
ECU FLASH
The BMW F10 M5 is one of the quickest sedans to hit the market. With the v8 4.4L twin turbo engine, there is tons of room for more horsepower and torque. Why is this? Because to meet emissions and government regulations, BMW must tune the car to be conservative. Huge power is lying in wake and VR Tuned can help open that up! The test BMW M5 F10 was tuned on a Maha Dyno using 93 octane gas by our tuning partners. The results is a unprecedent gain in power. The car went from 560bhp to 630bhp. Thats a 70bhp gain! The torque was massive going from 680nm to 800nm. This means the torque gain was nearly 120nm over stock.
Upon ordering of this ECU Flash Tune, you will be required to send in your ECU. Once we receive the ECU and program it, we will ship it back to you via the method you select at checkout. This requires the ECU to be mailed in to us to be benched flashed. Bench flashing requires the ECU to be opened. We DO NOT solder or modify your board in any way. Using a electrical contact pins, we tie into the boards programming mode to read and write the file. We do store your stock file if you ever want to revert. Because the ECU must be removed and opened, if you are concerned with warranty, you may want to speak with your dealership. Removing the ECU takes about 20 mins depending on the vehicle. With the VR Tuned ECU Flash, basic bolt-on performance parts will not require a retune of your ECU. We are able to do tunes that will allow you to run catless downpipes and raise the VMax aka speed limiter. If you add higher octane fuel, the ECU will adjust accordingly. Anytime you add higher octane, the fuel will burn slower providing your vehicle with improved performance. We never recommend using leaded gas such as C16 as this will destroy your O2 sensors and catalytic converters. Further custom tuning is available with provided dyno sheets or datalogging.
ECU Tuning Box Kit
This tuning box kit is a plug and play solution to tune your cars fuel, timing, and boost giving you up to 40% more power and 20% fuel savings. The VR Tuned ECU Tuning Box Kit gives your turbocharged BMW M5 engine a gain in power from 560bhp to 610bhp gaining you 100hp!
Plug and Play for easy removal to avoid warranty issues
Designed for turbocharged vehicles only
Does not lock to vehicle or VIN
Harness has OEM style connectors, no splicing or cutting
Tuning Box features an aluminum weatherproof case
Digital Microprocessor Controlled
Installs in 5 - 45 minutes.
Proven power gains
3 year warranty on parts
Tuning Box cannot eliminate CELs from catless or high flow cat exhaust parts
On the back of the box is a removable cover with dial settings you can adjust. This is to allow small adjustments to the power setting so the box can work correctly in different climate conditions and on different quality fuel.
OBDII Port Tune Auto Flash
The OBDII flash adjusts fueling and timing.
The mapping works in accordance with factory knock and engine sensors.
With changes to ignition and fueling, the car has improved throttle response, torque, and mid-range pull.
As tested on our own vehicles, we KNOW these work and your satisfaction is guaranteed!
Undetectable by dealers.
Does not change the ECU flash counter.
Does not change the file size of the ECU map.
Bypass anti tuning without having to remove the ECU.
Have warranty concerns, flash it back to stock!
Did the dealer update your vehicle firmware, reflash the ECU again!
Ordering
Phone:
You can reach me directly by calling 480.966.3040 ext 243 to place your order over the phone.
Payment Methods:
We accept payment via Credit/Debit Cards (Visa, Mastercard, Discover, American Express), Paypal, Bank Wire Transfer, and Bill Me Later. We welcome all forms of payment for United States and Canada. For international clients, we require payment via Paypal or bank wire transfer.
Shipping:
We ship all over the world, and offer very competitive rates in doing so. The majority of our shipments are shipped fully insured via FedEx, however we do utilize UPS, DHL, and various freight companies as well. The most efficient shipping method is always chosen. Expedited shipping is available per request.
Hours of Operations:
Here in Arizona, we do not have Daylight Savings time. As such, our hours of operations are as follows:
March-October: Monday through Friday 9am-6pm PST
November-February: Monday through Friday 8am-5pm PST
We are closed for business Saturday and Sunday.
Contact Info:
Phone: 480.966.3040 x243
Email: alex@vividracing.com
Website: www.vividracing.com
Feel free to contact me via PM, email, or phone if you have any questions.
