      08-30-2014, 11:54 PM   #1
hyde
hyde's Avatar
Drives: 2024 X3m40i
F15 vs F10 dimensions
Where can I get an overlay comparison of the two vehicles? If not overlay I'd be happy with readable dimensions that I can just print because what I see on BMWNA as dimensions outline is totally unreadable with numbers extremely small.
      08-31-2014, 09:00 AM   #2
EJL
Drives: 2016 340i
Cars.com has a good compare car feature. No graphical overlay, but it will list the specs side by side if you spell out specific models.
      08-31-2014, 09:04 AM   #3
s62
Drives: Yellow
I use kbb
You go to Research tools then Compare cars
http://www.kbb.com/compare-cars/spec...bmw-x5-393195/
Go to the Technical Specs tab to check dimensions. Most values are often populated but some new vehicles data may be missing.
Regards
      08-31-2014, 10:06 AM   #4
F15 official specs/info: http://f15.bimmerpost.com/forums/sho...d.php?t=846222
F10 official specs/info: http://f10.5post.com/forums/showthread.php?t=324662
All our official threads with all official specs/info/etc. are listed on the homepage section. Check it out at: http://www.bimmerpost.com/official-threads/
      08-31-2014, 12:40 PM   #5
hyde
hyde's Avatar
Drives: 2024 X3m40i
Thanks for the replies, Jason's post especially is a great resource, I didn't realize there were specifically designed to have all info in one post like that.
cars.com and kbb had a bit of conflicting information when it came to specs, knowing that certain things were actually standard it listed as option or not available, those were some very basic stuff. So lack of that info made me question the rest of the specs. Thanks s62, the specs listed for dimensions seem to be accurate.
The reason I asked for comparison like overlay was to get an idea visually which helps a lot. I think I can use Jason's PDF files and just use photoshop to overlay them.
Thanks again.
      08-31-2014, 02:45 PM   #6
hyde
hyde's Avatar
Drives: 2024 X3m40i
      08-31-2014, 02:51 PM   #7
hyde
hyde's Avatar
Drives: 2024 X3m40i
The only info that's missing is ground clearance, which is absent from KBB as well.
