01-04-2014, 01:45 AM | #1 |
Certified Trainer
Rep 73
Making 2013 M5 as good as 2014 M5 CP
I keep hearing how much improved the ride is on the Competition Package M5's. (the ride on my 2013 is pretty damn good).
What do I need to buy to make my non CP M5 as good as the CP M5? What makes it significantly better than the 2013? |
01-10-2014, 08:06 PM | #2 |
Perennial PFC
336
Rep 1,274
I also think the standard F10 M5 rides very well, and don't have a good answer to your question. But, I'm going to start with changing out the front sway bar for the CP bar from 7/2013 production onward. I've been told it's 29mm versus the stock 25mm bar, so will be somewhat stiffer. It comes with the properly sized rubber mounting bushings, so I'm hoping it will be an easy remove and replace. I don't imagine BMW would have changed the shape of it to require new suspension linkage. I'm still debating how to proceed with the rest of the suspension, coil overs or perhaps the CP springs, but the sway bar would be the same change with either, so it's a safe start. If my budget would allow I'd buy the BBS F1 wheels with the extra width and lighter weight to slip on slightly wider tires.
01-12-2014, 12:19 PM | #3 |
Rep 1,622
The CP Suspension involves new:
Struts Springs Front sway bar (front sway bar links are the same) Rear shocks Rear sway bar Rear sway links If you install the CP springs, you should install the struts/shock along with it. The front and rear sway bars could be installed alone without issue, but the same cannot be said for the springs as they should really be paired with their counterparts.
01-12-2014, 06:24 PM | #4 | |
Perennial PFC
336
Rep 1,274
I'd love to take a stock spring and a CP spring, both front and rear, to a shop who could measure the difference for me. I hear quibbles that they are progressive rate and difficult to measure.....BS! If you want you can compress the spring mm by mm if you wish and measure the pressure at each point. Whatever it is at that dimension for each spring will tell you the difference in the rate at that point. I'm sure there is a shop willing to do that. I disagree slightly with avinch over the necessity of combining the spring and strut. There is over lap in the three settings on either shock, stock or CP, and it might be possible that one setting from the non CP shock may work better at one track with the CP spring, and vice versa. I know I'm splitting hairs, but it is really only on the track that these minor increments of adjustment are relevant. Street use, I don't think we will notice the difference. |
