09-28-2016, 11:06 AM | #1 |
Rep 294
Details around the F10 M5 Diff fluid change
Anyone have details on how many quarts and the fluid type/part number to do the diff fluid change? I usually like to flush it every <30k miles.
10-01-2016, 04:20 PM | #3 |
Rep 10,185
M5 Rear Diff is listed as having 1 Liter filling quantity
Ask you dealer whats the USA part number for the fluid as they aften differ from Euro numbers (Euro is 83 22 9 405 462)
01-06-2017, 09:49 AM | #5 |
Rep 294
Anyone know how many quarts needed to flush F10 M5 diff?
I found the oem fluid part# 83222282583
01-06-2017, 01:02 PM | #6 |
Rep 165
Lemme know how many u need. I need mine done
BMW M5 | Singapore Grey | Sakhir Orange | Turner Muffler Delete | Alpha Catless Downpipes | RamAir Intakes | ESS Tune E-700 | Performance Front Lip | Performance Wing | Stance SF07 20X9(20ET) 20X10.5(27ET) |
01-19-2017, 10:04 AM | #7 | |
Rep 294
Dealer said 3.17 quarts are needed for a flush change https://www.amazon.com/gp/product/B0...A2BJUXTHZ4WM45
Gone:2013 F10 M5-DCT-Montecarlo Pearl Blue-BBMR 800 Stage 1 system 700whp+(93oct) 2004 Lamborghini Gallardo-Manual-Giallo Midas Pearl Yellow-Modified 2018 Range Rover Velar S-White Last edited by steeve13m; 01-19-2017 at 10:25 AM.. |
04-19-2017, 06:26 PM | #8 | |
Rep 294
Gone:2013 F10 M5-DCT-Montecarlo Pearl Blue-BBMR 800 Stage 1 system 700whp+(93oct) 2004 Lamborghini Gallardo-Manual-Giallo Midas Pearl Yellow-Modified 2018 Range Rover Velar S-White Last edited by steeve13m; 04-20-2017 at 05:33 PM.. |
04-19-2017, 06:46 PM | #9 |
Rep 149
Dealer just did mine as part of regular maintainance service.....oil and diff....44k miles
Other toys
'07-997 Turbo....EVOMS 580..AWE exhaust...champion intercoolers..champion springs. '91-964 Turbo K27 Hf turbo...Techart Exhaust...etc, etc |
12-22-2017, 11:26 PM | #10 |
Rep 553
12-24-2017, 02:22 AM | #11 | |
Rep 11,891
12-24-2017, 04:17 AM | #12 |
Curve Thrasher
623
Rep 3,773
Flush your brake fluid also at the same time if you can.
Country run |
12-25-2017, 09:40 AM | #13 |
Rep 294
12-28-2017, 10:11 AM | #14 |
Rep 1,123
I don't think the rear diff takes 3qts on a change. A bit over 1 liter is about right (bit over a 1qt). If you don't use the original BMW stuff, make sure to add a 'friction modifier' to the oil. Otherwise you'll get chattering in the future. BMW puts the modifier in it's oil (written on the bottle)
I would go with 75w-140 synthetic Castrol. I actually just double checked....the Castrol LS 75w-140 has friction modifiers in the oil also. Last edited by Fast400; 12-28-2017 at 12:55 PM.. |
12-28-2017, 10:37 AM | #15 | |
Rep 294
"Lucas SAE 75W-140 Synthetic Gear Oil is a non-foaming, super slick, long lasting lubricant designed especially for heavy duty or high performance applications where regular gear lubricants just aren't good enough. Contains a special additive package that cushions gears and resists squeezing out under extreme pressure situations where other gear lubricants just aren't good enough. Specially designed to stand up to high temperatures without losing its lubricity. Excellent for use in limited slip differentials. "
12-31-2017, 10:53 AM | #17 | |
Rep 1,123
AWF10M5223.50 |
12-31-2017, 01:56 PM | #18 |
Rep 553
thx will be ordering the ECS kit along with the transmission kit
01-01-2018, 12:33 PM | #19 |
Rep 294
The ecs kit also comes with 2 quarts? My car took 2 quarts.... 1 quart doesn't sound right when total capacity per dealer is 3.17 quarts...can anyone else confirm?
01-01-2018, 01:09 PM | #20 |
Rep 1,123
I let mine drain for 45minutes.... 0.95 liters came out. Tried to squeeze more in, wasn't happening.
01-01-2018, 01:28 PM | #21 |
Rep 1,123
Here's a link: http://endodojo.com/bmw/Training/F10...bimmerpost.pdf
It states 1.2 liters |
