07-14-2020, 08:55 PM | #1 |
Rep 105
Should I find a new service center?
I recently went in for an oil change and differential change, brought my own parts purchased from fcp euro. Technician states I didnt bring enough oil and differential fluid was for mercedes. I thought our cars take 8.9 quarts of oil or am I wrong?
07-14-2020, 10:40 PM | #2 | |
Rep 122
https://www.newtis.info/tisv2/a/en/f...ngine/GIXXgkBH If you look on most oil change kits from reputable vendors [[ https://www.blauparts.com/bmw-m5-oil...0-v8-5w-40.htm ]], you'll see they sell the filter with 9 Liters of oil. I recently did my own oil change with 9 Liters and the oil measurement was right at the max full line. For the rear differential, did you really take a Benz branded oil? Even if the weight is right, I guess I'd understand if the dealership refused to put in anything not their own. |
07-14-2020, 11:19 PM | #3 | |
Rep 105
07-15-2020, 05:41 AM | #4 |
Rep 634
Just had my oil changed, and the receipt states 9,5l of motor oil.
On the diff oil, BMW "hide" the spec behind MSP/A, but a search shows it a 75w-140 oil, unless there is a misspelling in the print out (75w-40) they are correct in not using that oil. If the Mercedes oil is in fact 75W-140, there should be no reason to reject that oil as it meets the same spec. However, MSP/A being a BMW spec, there may be special additives in the oil that is not in the MB oil. Looking at the parts catalogue, the MSP/A replaces the old Castrol SAF-XO diff oil BMW used. I guess this is because BMW and Castrol split few years ago, and I believe BMW is now working with Shell as the supplier of BMW OEM oil.
_____________________________
-14 Imola Red M5 Competition Pack (sold) -90 BMW 850i Supercharged -20 i3s -20 Ducati Diavel 1260s |
07-16-2020, 02:40 AM | #6 |
Rep 19,618
07-16-2020, 10:42 AM | #10 |
Rep 105
all my docs say 8.9 quarts, i provided 9 litres which is well over that, just concerned that my tech isnt very well trained and may have not used my provided oil if he thought it wasnt enough. I switched to the 5w 40 liqui moly to help slow the burning of oil..
