09-22-2016, 03:15 PM | #1 |
Rep 233
Who would you use for install...
I've got an AWE Tuning Axel Back exhaust arriving tomorrow with install scheduled for Monday. I'm curious on who you guys would use to do the install. Below the ones I called and the cost:
1. BMW Dealer: $420 2. Independent Shop that specializes in BMW and other Eurobrands: $180 3. Independent Shop that only does BMW: $250 4. Independent shop that only does (custom) mufflers/exhaust work: $75 an hour and thinks it's 2 hours max if not less I booked an appointment with #4 because I feel like it's not rocket science to do an axel back and that a shop that focuses on mufflers and exhausts (good reviews on google/yelp/Angies List) can easily do this. Their cost isn't that for off from #2 so that was the other I was considering. I think the dealer is out of their mind and provides no real additional value. It would be a DYI project if I had ramps and tools to cut the stock pipes, but I think I'd rather a pro do it... Thoughts? Last edited by djseto; 09-22-2016 at 08:30 PM.. |
09-22-2016, 07:40 PM | #4 |
Hide! My wife's coming!
812
Rep 2,816
I'd go with #4 but I'd make sure they do it right. You're right, it's not rocket science and muffler shops are more than capable to do it, however, some like to take short cuts.
Make sure to set your expectations and check them for quality of work. Believe it or not, I've seen BMW fuck up aftermarket installs. Not worth the price and it's not their speciality.
09-22-2016, 11:29 PM | #5 |
Rep 160
#2 or #3......
you could go to #4 but the guy putting your car on the lift might not give a shit and scratch your side skirts putting it on the lift or climb into your car super filthy... too many variables. go to the specialty shop. |
09-23-2016, 04:19 AM | #6 |
Rep 788
#5 - do it your self... 45mins to an hour on a jack with axel stands
Skeeter_f1056.00 |
09-23-2016, 06:50 AM | #7 |
Rep 1,805
Drives: 2014 BMW M5 F10 CP
#4 regular muffler shop. The others will probably not have lots of experience changing out exhausts from OEM to custom - and you'll have to end up there anyway to get the exhaust checked!
09-23-2016, 04:01 PM | #9 |
Rep 233
Does the M require anything special to be put on a lift? I know my Corvette (C7) needed these special pucks between the lift and the car.
09-23-2016, 09:03 PM | #10 |
Rep 788
Yes - you can buy the pucks from BMS etc or make your own from alloy, steel or dense plastic like PU etc.
... you can get away without but if you are very unlucky damage the plastic jacking points on the car but they are easliy replaceable... 2 minute job and about $20 for the part so no biggy- as long as you use axel stands its all good. |
09-23-2016, 09:04 PM | #11 |
Rep 788
09-26-2016, 07:56 AM | #13 |
Rep 233
I didn't want to use names since I don't want to put their prices up with asking, but I did call #4 to ask about jack pads and the guy says "well....we could just use one of several drive on lifts."
Will report back in a few hours after it's all done. |
09-26-2016, 12:43 PM | #14 |
Rep 406
This is the easiest install. I did mine in the drive way with a sawzall and it took me less than 30mins. This should be NO longer than a 1hr charge at any exhaust shop.
09-26-2016, 01:10 PM | #15 |
Rep 233
It took 1.5 hours. I watched him do the install the whole time. They passenger side didn't quite fit as good as the drivers side. It hung a little uneven. He ended up partially cutting one of the hanging brackets at the weld near the muffler so we could bend it to be level withe the driver side and then he welded where he cut. He was probably more anal that I was about making sure everything was level and even on both sides. All in all, I was very pleased with the work for $100. I still can't believe the dealer wanted $420. That's just absurd.
