06-07-2018, 11:03 PM | #1 |
Rep 1,124
Would This Make an Engine Run Lean
Currently I have bolted BMS intake, piggy tune (conservative setup) and magnaflow exhaust. I’m planning to install catted AMS DPs in two weeks, or so. Will this setup cause my engine run lean?
06-07-2018, 11:51 PM | #2 | |
Rep 594
With high octane too If jb4 with meth kit its ok You can use big nozzle with map 8 You will be satisfied
Mohamed kamal elkasaby
06-07-2018, 11:54 PM | #3 |
Rep 1,124
I’m not a fan of JB4 and meth. I’m ok with getting a tune in order to prevent engine running lean
06-08-2018, 10:05 AM | #4 |
Rep 294
Ideal is running JB4+meth and running a compatible BEF(back end flash) to richen the air/fuel in relation to the JB4(plus all the BEF benefits like remove top speed limiter and cold start rev etc)....the OEM tune is already set too lean....end goal is more power than just an ECU tune
06-08-2018, 10:25 AM | #5 | |
Rep 1,124
06-08-2018, 02:42 PM | #6 |
Rep 294
Talk to your tuner and they may or may not recommend an update to adjust air/fuel ratio etc
06-09-2018, 07:08 PM | #10 |
Rep 1,124
I already purchased catted AMS DPs. I’m seeking input before I install them in order to avoid catastrophe. Ditching piggy tune is not an issue btw. I just want to make sure that running air intake, DPs and let’s say any tune, will not cause engine operating lean.
