      04-17-2019, 11:32 AM   #1
His4
His4's Avatar
38
Drives: F13 M6
Why my Injectors looks like this
Hey there,
I got drivetrain malfunction in cylinder 6 and i decided to replace them.
After i pull out the injektors from Bank 2 i'm affraid.
Injektor 5-6 looks very dirrty.
Does anyone know why they look like that?
      04-17-2019, 01:33 PM   #2
Jasoneo5
Drives: 997 TTs, GS-F, RS6, M6 GC-sold
How many miles? What year is your car?
      04-17-2019, 01:36 PM   #3
His4
His4's Avatar
38
Drives: F13 M6
68k miles
2012
But injectors was changed by BMW about 2 years ago.
      04-17-2019, 06:50 PM   #4
AirBull
AirBull's Avatar
Drives: 2015 BMW M5
2015 BMW M5  [0.00]
Not sure why your injectors look the way they do, but running some Redline SI-1 every so often will only help keep them clean and in top working order.
      04-18-2019, 06:30 AM   #5
Drives: Black M5
Run some Torco Octane Booster, and your injectors will clean up.
      04-19-2019, 09:23 AM   #6
His4
His4's Avatar
38
Drives: F13 M6
problem solved.
It was a cable break on the brown cable, which goes from the dme to the injector 6.
      04-19-2019, 10:01 AM   #7
technician117
1990 BMW M5  [0.00]
2000 BMW M5  [0.00]
2013 BMW M5  [0.00]
That's odd. Glad you fixed the issue! Hard to tell from the picture, but is the connector clip broken or the wire itself half broken right behind the connector?
      04-19-2019, 10:10 AM   #8
His4
His4's Avatar
38
Drives: F13 M6
Yes, the connector clip breaks, when i pulled the cable out from the plug
      04-19-2019, 10:26 AM   #9
Jasoneo5
Forgive my ignorance, but how would this make your injectors dirty? Wouldn't it simply cause the car to go into limp mode and be inoperable? Thx
      04-19-2019, 10:42 AM   #10
His4
His4's Avatar
38
Drives: F13 M6
I dont know why Injekotr 5 & 6 is so dirty.
First i thougt, the Injektor was broken and that would be the issue for drivetrain error at injektor 6.
After i replace all Injector 5-8 , the drivetrain error at Injector 6 was still there.
      04-20-2019, 07:23 AM   #11
technician117
1990 BMW M5  [0.00]
2000 BMW M5  [0.00]
2013 BMW M5  [0.00]
Thanks for the clear photo and confirmation. Good job diagnosing. Some people would struggle for a week or more before discovering bad wiring!
      04-20-2019, 10:17 AM   #12
His4
His4's Avatar
38
Drives: F13 M6
Your welcome.
I have now repaired the plug and the engine runs without problems.
