      07-14-2018, 02:16 PM   #1
Dwaynos
Dwaynos's Avatar
New tyres
I'm getting closer to needing new tyres and still trying to find the best option. I really want to go for 305s on standard 20" m5 wheels. I understand that the recommended width is 10.5" but I also understand that the 305s can be used on 10" wheels.
I plan on using Michelins as they have been praised on the forums.
I'm looking at Michelin Pilot Sport 4S PS4S - 305/30 R20 (103Y) XL TL
Has anybody used these tyres without problems?
Thanks
      07-15-2018, 01:10 AM   #2
Mr. M6
Mr. M6's Avatar
149
Drives: M6
2014 BMW M6 F06  [9.25]
i have 4S 305 on oem 433 wheels and no problem at all...
      07-16-2018, 02:10 PM   #3
Dwaynos
Dwaynos's Avatar
Won't yours be 10.5" though with them being m6 343m wheels?
      07-17-2018, 03:09 AM   #4
Mr. M6
Mr. M6's Avatar
149
Drives: M6
not sure if my wheels 10 or 10.5...
      07-17-2018, 12:24 PM   #5
Dwaynos
Dwaynos's Avatar
Anyone else? Surely someone can help.
      07-17-2018, 12:48 PM   #6
hirkaismyname
Drives: F06 CP GC
Bump, I'm interested too!
      07-18-2018, 07:06 AM   #7
Darkshear
Darkshear's Avatar
Drives: BSM 2019 M5 Comp
Should fit. 343M's are 10.5, Competition 601M wheels are 11.0, and my aftermarket wheels are 10.5--I run the 305/30 (103Y) Pilot Sport 4. Sidewalls are beefier but they fit fine.
2021 Brands Hatch Grey M5 Competition
      07-18-2018, 08:46 AM   #8
Dwaynos
Dwaynos's Avatar
Stock 343M M6 wheels are 10.5", stock M5 wheels are 10"
      07-18-2018, 08:54 AM   #9
Darkshear
Darkshear's Avatar
Yes sorry--you're right.
      07-18-2018, 11:40 AM   #10
Advantage
Drives: 2019 BMW M5 F90 Competition
I put Nitto tires on my M5 recently. I should have done this years ago as the grip and comfort far exceed the Michelin's IMO.
I went with Nitto's NT555 G2 in the front and NT05 (305s) in the rear.
      07-18-2018, 01:32 PM   #11
steeve13m
Thats exactly the setup I have now
      07-19-2018, 08:15 AM   #12
Advantage
The car should have left the factory feeling this good and planted.
      07-19-2018, 01:27 PM   #13
hirkaismyname
Drives: F06 CP GC
Advantage steeve13m
What are your respective sizes in the front?
And, any objections against going with the PS4's? In Florida, we get an occasional afternoon shower, basically on a daily basis currently.
Thanks,
H
      07-19-2018, 08:33 PM   #14
Advantage
Originally Posted by hirkaismyname View Post
Advantage steeve13m
Thanks,
H
Fronts are 265 35R20
      07-20-2018, 12:44 AM   #15
hirkaismyname
Drives: F06 CP GC
Did either of you both try the 275 combo? I've read that it may cause the vehicle to understeer...and further the issue of the camber being -2 from the factory.
Is this true? If so, what are your respective camber/toe settings?
Thanks,
H
      07-20-2018, 05:38 AM   #16
Nikolov
I'm running 275 in the front and 305 in the rear. It doesn't make sense that the vehicle will understeer with a wider tire in front, as it should give the front tires more traction.
I haven't noticed any negative effect from running 275 in the front, but then again I don't track my car either.
The PS4S is a great tire in both dry and wet conditions. Aside from semi-slick tires, you'll probably have a hard time finding a better tire.
      07-20-2018, 08:53 AM   #17
technician117
1990 BMW M5  [0.00]
2000 BMW M5  [0.00]
2013 BMW M5  [0.00]
Keeping with the thread topic, (wheel widths) does anyone run a square set up with 4 rear wheels? Or 4 rears but still staggered tire sizes...
I have an opportunity to buy (4) rear Dinan wheels (20" x 10.5") at a big discount. I know I'd need a spacer in the front, but I'm curious about handling changes. Can you run a 285 tire on a 10.5 rim?
      07-20-2018, 04:35 PM   #18
Advantage
Thanks,
H
I didn't try 275s in the front as my "tire guy" recommended to stick with 265s in the front for fitment. I went ahead with his recommendation.
      07-20-2018, 10:39 PM   #19
steeve13m
I run 275 in the front...great setup
      07-21-2018, 08:53 AM   #20
hirkaismyname
Drives: F06 CP GC
Thanks ya'll! Very helpful information.
      07-21-2018, 11:09 PM   #21
Spinny02
Spinny02's Avatar
275/305 on CP wheels. The 275s add a bit of stress to the power steering but i still keep putting them on...
