      08-08-2022, 09:55 PM   #1
m5bbq
Drives: M5's
is there special "diagnostic mode" to have my ISTA connect to F10 m5?
hi. I just purchased F10 M5. I have had E60 M5. My ISTA connects just fine to E60 but wouldn't read vehicle information on the F10. I'm using bimmergeeks cable. The error window mention something about diagnostic/testing mode. Is there a special mode I need to set on F10 M5 to be able to be read by ISTA computer?
Thanks in advance. sorry for multiple posts. seemed unrelated.
      08-09-2022, 07:28 PM   #2
OnlyGerman
OnlyGerman's Avatar
Drives: F15, F13, F10, E60
Bump
      08-09-2022, 08:57 PM   #3
AlisterB
Are you using an ENET (ethernet based) OBD cable?
I think the cables are different for E series and F series and beyond models.
      08-09-2022, 10:46 PM   #4
m5bbq
Drives: M5's
I'm using Pro K+DCAN cable. It says F-chassis should work on the website. The setting should be correct since it works with my e60 m5. I ordered Carly a week ago, so when it gets here, I'll try again. Any advice would be appreciated.
      08-09-2022, 11:10 PM   #5
AlisterB
Pretty sure you need an additional adaptor to use that cable with an F series or newer car (like their ProTool adaptor). Or just use an ENET cable.
      08-10-2022, 07:32 AM   #6
m5bbq
Drives: M5's
excellent, that's a great tip. I'll message them now. Thank you
      08-10-2022, 08:25 AM   #7
m5bbq
Drives: M5's
bimmergeeks responded on fb msg and got me squared away on teamviewer. it was the software issue. It works fine now for f10 m5. Thanks!
      08-12-2022, 02:25 AM   #8
AlisterB
Good result and sounds like quality support from Bimmergeeks.
