02-01-2015, 11:06 AM | #1 |
Rep 44
Any one have a sidewall problem on their M5's
Well I have 967 miles on my new beast and was headed from Houston to Fort Worth. I was enjoying the drive when just after turning off I-45 to get on US 287 near Ennis, my TPM said I had a tire issue with my driver's right tire. I checked the pressure and sure enough it was low. Since I really hit nothing, I thought it must be a slow leak. Well when I filled it up,I could hear the air coming out. I wen to a small tire dealer and they showed me the cracked sidewall. I then called BMW assist and in 90 minutes I had a flatbed taking me to Autobahn BMW in Fort Worth. Of course the service guy asked me about my tire and wheel protection. My dealer wanted $2495, so,I skipped it. I told him it would be ridiculous if this was caused by a road hazard and said look at the side wall, no marks. I aid you can see if the rim is bent, because I hit nothing.
My question is I googled Michelin side wall failures and found some for the Pilot Sport. Has anyone else had a similar tire failure and what did the dealership do? |
02-01-2015, 11:29 AM | #2 |
Alpina!
357
Rep 293
Sounds like the dealer needs to reach out to BMW but given that you barely have 1000 miles on it, and there is no sign of damage I suspect BMW will cover it as good will..
2021 Alpina XB7 - Alpina Blue
2022 M5 CS - Frozen Gray |
02-01-2015, 12:44 PM | #3 |
OIF Veteran
246
Rep 2,106
Not sure if you had much of a choice, but going to Autobahn BMW was probably mistake. It's not the first time they've tried to screw a customer.
See epic story here from an experience from m5board http://www.m5board.com/vbulletin/e60.../topics/162450
Retired: '06 BMW E46 ///M3
Current: '08 BMW E60 DINAN ///M5, Interlagos Blue, SMG DINAN Stage 2 Suspension, Exhaust, Stage III Software, Front strut braces, Intakes, 13% Underdrive pulley, 3.91 Differential, RPI Scoops. |
02-01-2015, 01:31 PM | #4 |
Rep 1,840
Mich. should cover the tire under their warranty for something like this. You should keep the tire and file a claim. Assuming the dealer does not take care of you.
02-01-2015, 02:20 PM | #5 |
Rep 395
Tire and wheel is the only package you should get. Big mistake.
02-01-2015, 02:57 PM | #6 |
Rep 44
At $2495 tire and wheel,is a ripoff. Let's see how I do! Seriously... Big Mistake?? I think other things in life are Big Mistakes, small mistake maybe. I have bought tire an wheel on half of my BMW's. I did it on my 650i with RFT's. In that case I know you could not fix those tires. These tires can get patched...except when you have defective sidewall.
02-01-2015, 03:16 PM | #7 |
Rep 6,066
Let me share my experience since is similar to yours.
Back in September 2011 I got my first F13 650i. After about 5k I saw bubble on side wall of front tire. I'm not sure it was Dunlop or Goodyear, but I visited the dealer. They denied replacement the tire so I visited the tire shop who was the rep of that tire. As soon as the guy saw the tire he said yes this is definitely factory defective parts and contacted the factory. Long story short he replaced all 4 tires for FREE because that tire was not available so he replaced all 4 with brand new Bridgestone Potenza. I believe you have to go the same way.
02-02-2015, 03:24 AM | #8 | |
Rep 315
Drives: 13 AWSO M5,16 DGMR X5M
2012 Rosso Mars Lamborghini Gallardo STS LP570-4
2013 AW SO F10 M5 upgrades: RKP front spoiler, M performance carbon spoiler, 3D design rear carbon diffuser, KW HAS Sleeve Kit, Akrapovic Evolution Carbon tips, ind black LCI front and rear grills, GruppeM RAM intake, 20" HRE P104 satin charcoal with PSS tires) |
02-02-2015, 08:25 AM | #9 | |
Rep 395
02-02-2015, 11:39 AM | #10 | ||
Rep 1,840
