Go Back   M5POST - BMW M5 Forum > BIMMERPOST Universal Forums > Off-Topic Discussions Board > Photography/Videography
      08-10-2011, 03:21 PM   #1189
The1
Drives: white 135
Originally Posted by Chewy734 View Post
Thanks guys. Battery just got charged. Hmm... in Av mode, the camera automatically chooses your ISO depending on what you're focusing on?
only when ISO is set to auto, you can choose it yourself.
if not, check what firmware you're on, and that may be in an update, could be wrong though.
      08-10-2011, 03:23 PM   #1190
Chewy734
Drives: 2006 BMW 330i ZPP, ZSP
I'm running 2.0.9. Damn, this camera is more complicated.
I was hoping I wouldn't need to open up the manual, but it's not obvious how to turn off auto ISO.
      08-10-2011, 03:24 PM   #1191
The1
Drives: white 135
no need to open manual.
ISO button is on the top, then rotate top finger dial to desired ISO setting.
      08-10-2011, 03:37 PM   #1192
Chewy734
gracias. I can't believe how much wider this... at 17mm it's awesome.
      08-10-2011, 03:38 PM   #1193
The1
Drives: white 135
gracias.
you can also get down to 50 ISO, but you have to get into some of the extended menus, I pretty much never shoot 50, the files jump up in size immensely, and there really is no purpose to it.
      08-10-2011, 06:11 PM   #1194
Chewy734
Do any of you guys use the BlackRapid RS-4 strap? If so, how do you like it? Is it worth it, etc?
      08-10-2011, 06:31 PM   #1195
The1
Drives: white 135
The single shoulder strap? If so, yes recommend, takes a lot of weight off the neck.
Great for walk about shoots, not so great for in session photoshoots, but even then, I donrt like having a strap
Also, if you have 2 cameras. One is at your side, and one on your neck
Definitely will recommend for you.
      08-10-2011, 06:38 PM   #1196
Chewy734
since the connector attaches to the tripod mount, does it scratch it up? Also, seems a little weird to have the camera dangling by your hip... is that comfortable?
      08-10-2011, 06:42 PM   #1197
scollins
Bootleggin' 'n Gunrunnin'
scollins's Avatar
137
Drives: 2024 X3 M40i
I've got the RS-7 and it is a great strap! I bought it before the RS-Sport or RS-Sport 2 came out (which I would have bought instead), but the RS-7 is still great. I like the curved pad better than the standard RS-4 setup.
It holds my D3 + 70-200 quite comfortably for hours on end...
Scott
2024 G01 X3 M40i, Brooklyn Grey Metallic /// 2015 F15 X5 35i, Space Gray Metallic, 99K miles /// 2013 F30 320xi, Mojave Metallic, 112k miles
2019 Ford F450 STX, Oxford White
2013 Ducati Multistrada Touring S, Red
      08-10-2011, 06:46 PM   #1198
Chewy734
Thanks Scott. Would you recommend the RS-Sport 2 over the RS-4/7 line?
      08-10-2011, 06:55 PM   #1199
The1
Drives: white 135
Never noticed anything, its ruberized on the bottom of the camera, and the connector has rubber, so only concern is the rivits on jean pockets.
      08-10-2011, 06:57 PM   #1200
Chewy734
Oh, ok. cool. Thanks.
      08-10-2011, 06:58 PM   #1201
The1
Drives: white 135
Honestly, I bang my camera more off things when its on my neck. When its at your side, its right where your hand falls, so I'm usually holding it when its there.
      08-10-2011, 07:15 PM   #1202
rodi
183
Drives: your FACE!
Chewy, I guess you got your 5D already? nice!
2009 135i | space grey | sport | navi | hifi | heated
dinan stage 2 software | bmw performance exhaust
kw v2 | hotchkis front sway | vmr v710
      08-10-2011, 07:18 PM   #1203
Chewy734
Yeah man... got it today. I'm surprised they shipped it without any problems.
I'm thinking about walking down the street to check out the Avengers set. I figured since it's getting late, I can try out the 5D2 high ISO stuff.
      08-10-2011, 07:19 PM   #1204
rodi
183
Drives: your FACE!
dang, I only have 62,000 shots on mine. but I haven't used it much at all in the past tear and a half.
      08-10-2011, 07:20 PM   #1205
rodi
183
Drives: your FACE!
you mean they didn't call you to find out in which country you'd be reselling it??
      08-10-2011, 07:22 PM   #1206
Chewy734
haha, nope, amazingly. I thought I'd have to bitch them out at least once. It was smooth sailing though...
hmm... what lens to take? Not sure how close I can get to the set.
      08-10-2011, 07:25 PM   #1207
Chewy734
That's not bad... I think it's rated to 150k. You're not even halfway there yet!
      08-10-2011, 07:44 PM   #1208
rodi
183
Drives: your FACE!
300k. this is nikon we're talking about, not canon.
      08-10-2011, 08:14 PM   #1209
Chewy734
yeah yeah... I think it's 300k for the 1D line as well.
Thanks to excitement, I forgot that I was walking around downtown Cleveland after sunset... let's just say that walking around alone with nearly $3k of photography equipment didn't make me comfortable.
      08-10-2011, 08:29 PM   #1210
rodi
183
Drives: your FACE!
insurance!!
