10-06-2021, 03:13 AM | #1 |
Rep 99
Drives: BMW F10 M5
Error Code U0100 - Drivetrain Malfunction
Hello everyone, I recently put catless downpipes on my car. I have deleted the resonators and I am waiting on my JB4 tune to come in. I have also been driving the car with no issues for about a few days with the catless downpipes and it runs amazing. I am also waiting on the fabspeed muffler delete to come in for the car... the other day I was driving the car and I got on it a bit and got it to about 5000 rpms in 2nd gear and all of a sudden the car went into limp mode and immediately stated there was a drivetrain malfunction and it started behaving like there was a cylinder misfire. I safely got to my destination and it was turned off and detailed. When I started it back up there were no issues again while driving it, but when I gave it the beans again it did the same thing. Since then I have turned it off and on and it runs fine while driving normally around town and if i get on it a bit it is okay; however, as soon as I punch the throttle I get the same error code and the car goes into limp mode. I went to have the codes read as I thought I was experiencing a misfire, but upon getting the codes I noticed that I initially threw a code for Power Train system P0420 and in the Secondary DTCs the first code on the list is U0100 - Lost communication With ECM/PCM "A" and this seems to be the valid code...
Has anyone experienced this problem and if so what could it be, I have checked everything and it just doesn't make sense for what I am doing. Any advice on this? |
10-07-2021, 09:33 AM | #2 | |
Rep 174
10-08-2021, 06:46 AM | #3 | |
Rep 99
Drives: BMW F10 M5
10-08-2021, 07:01 AM | #4 |
Rep 538
It's not the tune, these cars run well with catless downpipes and no tune. I had a similar problem after going catless and spent a ton of money and time at various shops trying to find it.
Check your connections to the DMEs. I had a loose connection that would cause the car to buck and hesitate at higher rpms. This was because the wire was getting pulled out of its place. Also no codes, but an unrelated sensor one. Hope you get it fixed soon. |
ruben35691.00 |
10-09-2021, 03:36 AM | #5 | |
Rep 99
Drives: BMW F10 M5
10-09-2021, 09:47 AM | #6 | ||
Rep 538
Unfortunately that's all I was told by the shop, that a DME connection was loose. I took it to about 3 shops in total, one of which was a dealer, over the course of like a month. I was ready to sell it until the last shop found the issue. Where are you located? |
10-09-2021, 12:09 PM | #7 |
Rep 71
Just unclip your DME connectors and reinstall them, disconnect your battery ground first. When installing the connectors, push them fully into the DME without using the locking lever. If you use the locking lever to pull them together the plug will not fully engage the pins. The plugs must be fully pushed into the DME then locked with the lever!
10-17-2021, 04:34 AM | #8 | |
Rep 99
Drives: BMW F10 M5
10-17-2021, 04:36 AM | #9 | |
Rep 99
Drives: BMW F10 M5
10-17-2021, 04:40 AM | #10 | |
Rep 99
Drives: BMW F10 M5
