      03-02-2016, 03:42 PM   #1
r6321426
Drives: 2016 BMW M5
Smartphone Integration
Hi all,
I have a question about Smartphone Integration for 2016 M5. If I don't choose this option, can I still use iPhone to stream Music thru Bluetooth? is there any USB port for me to charge the iPhone?
Thank you.
      03-02-2016, 09:07 PM   #2
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
Originally Posted by r6321426
Hi all,
Thank you.
On 2016, Enhanced Bluetooth + USB includes BT Streaming Audio with Media Library Search, Mobile Office, and 2nd Phone Connection with Additional Microphone. USB ports are still there but on occasion for no apparent reason, will hiccup with BT Audio Connected. Some don't know two USB 12v outlet adapters are placed in the trunk at the VPC. Quite often they're missing before customer takes delivery.
      03-02-2016, 11:21 PM   #3
Scott@Radar-Mirror.com
Scott@Radar-Mirror.com's Avatar
75
Drives: 2016 BMW 550i
AFAIK you should be able to connect with Bluetooth. Mine doesn't always work. I bought a thing that goes inside the armrest for charging.
      03-03-2016, 09:14 AM   #4
r6321426
Drives: 2016 BMW M5
Thank you all for the response. I just have very good deal for a M5 but this M5 doesn't include Smartphone integration. Do you think that local dealer can install this option for us? or buy parts and install it by our own.
      03-03-2016, 12:36 PM   #5
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
There are retrofit kits available but it isn't cheap and requires a fair amount of labor to install. Looking at $1k or more depending on self or 3rd party installation. If you're purchasing or leasing for 3 - 4 years, personally recommend finding a car with the option especially if you use Apple devices.
      03-05-2016, 07:58 AM   #6
E90076
E90076's Avatar
235
Drives: X3M, M2CS, M5CS
Is the smartphone integration the physical black plastic piece that you can install a adaptor for depending on your phone model? If yes, my last M5 didn't have it and i used the usb port and bluetooth without any issues. I would suggest you try one at the dealer and make sure you're happy with the functionality before you buy.
      03-05-2016, 10:50 AM   #7
E90potentialbuyer
E90potentialbuyer's Avatar
Drives: 2015 M5 / 2009 335i xDrive
I have the enhanced BT on my 2015. Only reason I got is because dealer said I can have 2 smartphones connects at the same time through Bluetooth - so if I receive call on either phone it should go through car's Bluetooth. Horse crap. I can pair multiple phones but only have 1 phone active through Bluetooth at a time. If the 2nd one phone connects, then first one drops. I honestly have no idea what this feature is and why I paid money for it. Probably the only feature in the car that I have 0 clue on.
From what I understand even base M5's without this feature let you do Bluetooth calls and stream music through Bluetooth.
Someone referred to snap in adapter to plug in your phone - that is not part of the feature from what I understand. I had to buy my snap in adapter separately at the Welt. All it does is let's you charge your iPhone and get better connection (it's also the iPod feature where your music library shows up in iTunes but I can do same with Bluetooth).
Anyone care to share who knows?
2015 M5 Individual Moonstone Metallic / Special order Caramel/Black / Special order Walnut Honey Trim/ Comp Package / ED / Left the Stable :-(
2018 Volvo XC90 T6 POLESTAR
2018 AMG GT
2017 Fiat 500C Abarth
      03-07-2016, 10:20 AM   #8
r6321426
Drives: 2016 BMW M5
Hi, I finally got that M5 without Smartphone Integration. It can do music streaming by Bluetooth for sure and charge it by USB port. It is good enough for my needs.
      03-10-2016, 04:54 PM   #9
hybrid_eg
hybrid_eg's Avatar
Drives: 90 S13, 22 MSP, 23 JLUR 4xe
loaded or base model will be able to do BT music.. pair the phone and stream musing to BMW as you would to say apple TV or external BT speaker.. the problem is at least for me that connectivity is pure s^%$!! half of the time it doesnt work and you have to swtich back between XM or radio back to BT to get it to work.. never had issue with Iphone on any other devices besides BMW BT.. and the adapter thing inside the center console is for iphone 5.. who has iphone 5 these days? Lol.. i doubt they will ever make an adapter for 6 as car is stopping production this year.. so yeah.. if BT doesnt work i just go into XM and done with it..
      03-11-2016, 03:07 AM   #10
E90potentialbuyer
There is an adapter for iPhone 6 and there is an adapter for 6plus as well. I have them.
2018 AMG GT
      03-12-2016, 12:52 PM   #11
lemetier
Plenipotentiary
lemetier's Avatar
2614
Drives: Yes
Yes to answer this and the above, smartphone integration includes the adaptor cradle base plate, connection to HU including video (if supported by device), and external antennas.
      03-14-2016, 01:23 PM   #12
hybrid_eg
hybrid_eg's Avatar
great! When i was buying mine in July 2015 nothing was avail, good to know!
anyone have exact part number for Iphone 6? In my center console there already appears to be a section where the phone would go so I presume I need to buy entire cradle base plate/assembly etc?
      03-21-2016, 12:04 PM   #13
Johndong888
John
Johndong888's Avatar
Drives: '12 M3, '18 S560, '16 G63
I don't think the dealership would install it for you. The actual smartphone plate takes up a alot of room and BMW is painfully slow to release compatible cradles. I removed mine in the X5. There is a way you could code to enable 6NS which is the enhanced bluetooth. I'm not sure if you can still code it for free now or if it requires an activation code now.
But on to your original question, you will be able to stream and still have a usb port to charge. It's the same USB to update your maps so it will be standard. Your streaming just won't be "enhanced" with album arts, playlist, searching etc.
Current - 2012 AW/FR E92 M3 | 2014 AW X5 | 2015 MB S550 | 2016 RR V8 (White FTW)
Mods - BPMTune Stg1/Servo, Euro Visors & Side Mirror, IND Gloss Blk Pkg, OEM Perf. CF Trim/Spoiler, Grills, Lights, Pedals, Umnitza V4 AE, ModeCarbon GTS V1, 19" HRE P40
Sold - 2008 BSM/Black E92 335i
      03-27-2016, 04:24 PM   #14
Vitacura
Ich Liebe mein BMW
Vitacura's Avatar
Drives: 21 M240i CV, 23 X1
I have been going back and forth on this option as well. After some searching, it seems that the MY16 now comes with Enhanced USB and Bluetooth with the following features as a standard option:
Mobile Office – Text Messages, Email, Calendar, Tasks, Contact photos, Voice memos.
Bluetooth sync for additional (2nd) phone
Library browsing via Bluetooth
iSpeech – Voice control for contacts and music
The $200 Smartphone Integration option only adds the Base Plate for the adapter and connection to the external antenna as far as I can tell.
I chose to leave it out of my order, I connect one phone and use an IPod Nano via USB for music which should give me album artwork and track info etc.
      05-12-2016, 06:18 PM   #15
E90076
E90076's Avatar
235
Are you able to connect your phone via USB and search/play music through the USB port without the Smartphone Integration?
      05-26-2016, 08:23 AM   #16
Maverick997
Maverick997's Avatar
49
Drives: 2014 M5 Black Saphire Metalic
I am able to connect via BT but on music playback it shows the initial song/artist name and album art but that's it, as songs change the initial image remains and never changes.....any idea if this is car or phone issue? iPhone 6.
Other toys
'07-997 Turbo....EVOMS 580..AWE exhaust...champion intercoolers..champion springs.
'91-964 Turbo K27 Hf turbo...Techart Exhaust...etc, etc
      05-26-2016, 08:32 AM   #17
PEHM5
PEHM5
Drives: 2013 Monte Carlo Blue M5
2013 BMW M5  [0.00]
2008 BMW 328i  [0.00]
Yes.
