05-08-2017, 08:09 PM | #1 |
Rep 8,339
Options to get to 750 rwhp/rwtq
Just trying to do my research. It seems to get in this neighborhood, stacked dcm and jb4 tunes, intake, catless downpipes, exhaust, and dct clutches and I'm close. Correct?
Also, do the different exhausts matter for power or do they all make the same but vary in price, sound, and weight mostly. Same with intakes and downpipes. Thx.
'08 e93 AW 335i 6MT,Vargas Stg 2+ 20T clipped,VRSF catless dps & 7"FMIC,ER chargepipe&Tial, MMP inlets&outlets,Motiv Stg 2 fuel rail&dual disc clutch/fly, JB4G5,MHD w/Motiv tune,Fuel-it Stg 3 LPFP,Wavetrac LSD w/lockdown, KwV2,M3(Strut brace,frt control arms,steering wheel)AKE blk sub bush,re11 245/305,19x8.5et30&19x11et43,SmartTop,RE trans mounts,Msport rear bump & skirts,15%tint,ZSP knob,Stoptech rotors,241k miles
05-08-2017, 10:00 PM | #2 | |
Rep 843
05-09-2017, 12:01 AM | #3 |
Rep 881
To get above 700s whp/wtq, I'd say catless DPs, upgrade MAP sensors, custom flash tune, SSP clutches are the minimum. I also like the RK Autowerks intakes because they're proven to make power above 5k rpm.
There are other ways to get to >700s involving JB4, but that's not the route I'm taking. |
05-09-2017, 05:15 AM | #4 |
Rep 788
Exhausts post catless DP's are for making drone and nothing to do with power unless pushing 1000BHP+, money spent else where is a better bet.
You have three choices realy JB4+BMC+ Meth - removeable option DME Tune - you have to remove the DME's send them off by post if the tuner isn't local and then they have to open the glued cases or drill holes in the cases so there are signs of tamper DME Tune stacked with JB4 for extra features and flexablity (selectable boost per gear etc) You will need a SSP clutch come what may... Do your research, there are some good tuners on here. |
05-09-2017, 05:27 AM | #5 |
Rep 8,339
This is what i was looking for. So exhaust won't add power on this platform?
Good to hear about the autowerks. Any others? Not married at all to JB4 and I don't mind DME tampering |
05-09-2017, 06:06 AM | #6 | |
Rep 501
SSP Spec-R is a must. Your clutches are on borrowed time at 650rwtq+. Mine were toast at 39k miles. Now the car is a monster. Also recommend chatting with Mike Benvo at BPM. He has a very highly regarded reputation and has tuned many, many of our cars. Mike Benvo Best Brad
05-09-2017, 02:32 PM | #8 |
Sergeant
802
Rep 2,507
Do you guys think our motors / clutches are safe to run 630-640whp as long as we don't track and drive smart? What's the real risk ? Let's say intake, exhaust and flash tune only ?
'22 F92 M8 Competition Coupe - Frozen Brilliant White | 8 Speed DCT | Sakhir Orange/Black Full Leather | M Perf CF Exterior Package | M Perf. CF Exhaust | BBS FI-R 21" Wheels | |
05-09-2017, 07:32 PM | #11 | |
Rep 966
Rod bearings and such. Good question to put out there because we all know you can push the performance so far until something stock fails. Anything over 700 WHP is just waiting for something to fail in my opinion. Might not be right away but long term wise |
05-10-2017, 06:02 AM | #12 |
Rep 788
Clutch is more of a problem on the street than the track, on the street you can plant the throttle in a high gear at low rpm (less thn 4000rpm) and all the torque from 1800rpm up can slip the clutch, high revs and track use and you will probably be ok at higher levels.
05-10-2017, 11:07 AM | #14 | |
1087
Rep 1,968
schnell1982345.00 |
05-10-2017, 12:17 PM | #15 |
1506
Rep 676
Drives: '17 F31 340xi US Spec
The highest we have got stock turbo M5 was 767whp/787trq BUT that set the stock turbos way out of their efficiency range to the point that they were choking on a 50-300km/h pull. The sweet spot for stock turbos on these engines is about 35lb/min of air per turbo, and that roughly translates to 750crank HP (~650hp). At those power levels, you should expect the turbos to last some time and not have sleeve or shaft failures.
Bmw doubles983.50 |
05-10-2017, 02:05 PM | #16 | |
Rep 142
found a link here: https://www.pureperformancemotorspor...ting-rods.html |
05-10-2017, 03:43 PM | #17 | |
1087
Rep 1,968
05-10-2017, 06:14 PM | #19 | |
Rep 402
05-10-2017, 06:19 PM | #20 |
Rep 5,233
Doubt you'll get much 411 on a public forum regarding blown engines. Tunes, warranty issues etc.
Just my .02
05-10-2017, 08:21 PM | #21 |
Rep 881
I'm sure 90% of our driving is not at WOT, where running higher than 650whp for extended time will grenade the turbos too soon. That's why many can run stage 2 numbers because they're not on it all of the time. I'm aiming for 700s myself this summer on stock turbos, but I'm not too worried because I know MissionPerformance can do a good tune, and I know my driving habits.
05-10-2017, 08:39 PM | #22 |
Rep 8,339
Ok so if the turbos grenade im not so upset. I'm worried about the internals. What kind of power level can the internals take for a couple hundred k miles without doing a built motor?
