      03-05-2018, 07:12 PM   #1
allmotor_2000
1087
Drives: 2018 RS3, 991 Turbo
Power Comparison Pure S1 vs. S2 vs. X
Folks - given the evolution of this platform and the various things I have tried, figured it may help make a comparison on upgraded turbo systems.
The supporting mods are relatively the same (although for the Pure X... it was on stock exhaust), but intakes, downpipes, race-gas/methanol are baseline for all the combinations.
I would state that the Pure S1 and S2 plots are pretty much maxing out the turbos. The Pure X has some ways to go (both the turbo and supporting mods) and will update as I get more testing done.
Hope this can be useful in making turbo decisions.
m5 guy1691.50
V8munro49.00
jsnm70.00
      03-05-2018, 07:24 PM   #2
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
Thanks for posting up this comparison! Based on your experience if one wanted to stay at modest levels of craziness, so no x lol, which one would be best? I'm talking like a stage 2 fbo situation with the intent of just adding some turbos so nothing is maxed out. A nice efficient and moderately powerful setup. Not the best at explaining this here so apologies in advance.
      03-05-2018, 07:38 PM   #3
allmotor_2000
1087
Pure S2 set to about 740-750whp would get amazingly flat curve on both torque and horsepower to redline!
m5 guy1691.50
      03-05-2018, 08:32 PM   #4
TheHouseWon
TheHouseWon's Avatar
644
Drives: 2013 M5
You always have valuable data!
I wondered about the difference between FBO S63 vs. Built s63 w/bigger turbos. The low end torque is surprisingly strong on the S1 (quicker spool). I suppose in order to really enjoy your build, you have to play with it above 3.5-4k where the magic starts to happen.
m5james431.00
      03-05-2018, 09:06 PM   #5
m5 guy
m5 guy's Avatar
Awesome, just the response I was looking for. Thanks!!!
      03-05-2018, 09:18 PM   #6
allmotor_2000
1087
Other than freeway cruising in 7th, easy to get it to 3.5K and be in the power band. Better than other options where you don’t see much boost until 5K+
      03-05-2018, 10:33 PM   #7
Mcc420
Mcc420's Avatar
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
Thanks for takin the time to do this. Really appreciate it.
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53
F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml.
Ig @mcc420
      03-06-2018, 06:42 AM   #8
gdavis
gdavis's Avatar
35
Great to know, thanks!
'14 M5 CP
      03-06-2018, 09:01 AM   #9
Sales@RKautowerks
Sales@RKautowerks's Avatar
357
Drives: e92 m3
can you change it to 3 colors with dashed and solid lines. Hard to tell which ones which because of the thickness and the rainbow being on the screen.
-R
      03-06-2018, 10:07 AM   #10
KMORGSM5
KMORGSM5's Avatar
Drives: 14 CP M5
Good work!
      03-06-2018, 10:13 AM   #11
allmotor_2000
1087
-R
Lol.. power goes up from S1->S2->X... I am sure you can figure it out!
      03-06-2018, 01:02 PM   #12
bm5bullit
bm5bullit's Avatar
Drives: 2021 BMW M340i
You are the man. I have been going back and forth on which way to go on the turbo side. Now I know.
2021 M340i
2020 X3 M40i - her car
      03-06-2018, 01:48 PM   #13
V8munro
V8munro's Avatar
Drives: F10 M5 Sakhir Orange
Loving this, im going s2 and still will but the s1 to s2 difference is surprisingly small. The x follows its own lines completely though, monster
F10 M5 2013 Sakhir
Eventuri Intakes, Supersprint backboxes, catless downpipes, ssp spec r, ECU flash, JB4 BCM and BMS dual CM10 meth
Insta: Tommy_turb0
      03-06-2018, 01:55 PM   #14
V8munro
V8munro's Avatar
Do you know what sort of boost these numbers were achieved at for the hybrids? 30psi? And i assume race fuel, meth and map 6?
F10 M5 2013 Sakhir
Insta: Tommy_turb0
      03-06-2018, 03:11 PM   #15
allmotor_2000
1087
Lol... yes I should know the boost levels since they are from my cars
S1: 30psi peak... tapers to 25psi
S2: 28psi peak... tapers to 26psi
X: 34psi peak... tapers to 33psi
Limited testing obviously on the X, but the S1 and S2 were pretty much at the max for the turbos.
Yes, race-fuel, 100% meth and map 6, although the Map 8 with 75 additive should produce the same result.
      03-06-2018, 03:13 PM   #16
V8munro
V8munro's Avatar
Haha i should of worded that better, im sure you went over every aspect of what the cars logs were.
F10 M5 2013 Sakhir
Insta: Tommy_turb0
      03-06-2018, 03:15 PM   #17
allmotor_2000
1087
The biggest benefit of the S2 is that it holds way more power to redline (nearly 100whp) and can achieve peak hp/torque at a slightly lower boost level.
On the X... sky's the limit depending on what config is chosen. Can go for more peak power with a different turbine side but may affect the low/mid-range.
Depends what you are trying to achieve... peak dyno #'s or the ability to really get moving on asphalt.
      03-06-2018, 03:17 PM   #18
V8munro
V8munro's Avatar
Whats the deal with s2 not making 30psi? I understand it makes more power at less boost but i still thought it would make 30, is it due to the hot side snail being too restrictive?
F10 M5 2013 Sakhir
Insta: Tommy_turb0
      03-06-2018, 03:19 PM   #19
allmotor_2000
1087
It will make 30psi... just never held it for me upto redline. Other cars may have had different results. I'd say even without 30psi, my frozen gray M5 made 860whp. Best to ask Pure directly.
      03-06-2018, 03:21 PM   #20
V8munro
V8munro's Avatar
Ive been in contact with the european part of pure and guy has been more than helpful. Im itching to get it done just got to work abit harder to get the funds for them and the engine but ill get there with in a month i think.
F10 M5 2013 Sakhir
Insta: Tommy_turb0
      03-06-2018, 03:22 PM   #21
V8munro
V8munro's Avatar
Thanks for the info by the way very helpful
F10 M5 2013 Sakhir
Insta: Tommy_turb0
      03-06-2018, 03:45 PM   #22
PeterPure
PeterPure's Avatar
Belgium
677
Drives: BMW F80 M3
2017 BMW F80 M3  [0.00]
Tnx for posting this up! Very nice to see the differences!
