12-13-2015, 03:25 PM | #1 |
Rep 2,174
So I have a set of HR springs that I have yet to install and I think I'll finally have it done when I get my ECUs pulled for a tune. Thought about going with spacers as well and just get all of it done at once.
My question is what do you recommend for the size of spacers if it'll be a 1" drop in the front and 0.6" in the rear. Stock 343 wheels too. Would 12mm front and 15mm work without rub or would I be better off with 12mm all around? |
12-15-2015, 12:27 AM | #2 |
75
Rep 245
I had 12mm front and 10mm rear on mine with Dinan springs and it looked perfect imo, no rubbing at all. I have a gently used set of Macht Schnell spacers for sale http://f10.m5post.com/forums/showthread.php?t=1204485
12-20-2015, 12:43 PM | #4 |
Rep 324
15mm will cause rub issues , go 12mm.
I'm running 12mm front and 10mm rear and have no problems.
14 M5 F10 moonstone/SO
12-20-2015, 09:48 PM | #5 |
Rep 84
I have 12mm on all 4 corners and KW HAS springs. Perfect stance, no issues. Looks like it should rub but doesn't.
2013 M5 BSM/SS - BMS Stage 1, Turner Race Exhaust, 12mm spacers, KW HAS, Dinan sway bars, IND cosmetic package, LED kit, V12 coded
