05-08-2015, 11:57 PM | #1 |
Rep 466
DCT Transmission Oil Pump Upgrade
As many of you know the BMW DCT Oil Pump has been having failures. The dealers offer no upgrade but to purchase a new OEM unit. We as SSP have fixed the problem, so that you don't have buy a new 900.00 oil pump.
The failure is not the pump itself, but the bearings within the pump assembly. The DCT oil pump can operate at pressures above 18+ bar. The factory pump uses inferior needled bearings that fail. In time, these bearings wear out and cause catastrophic failure of the oil pump assembly. We have developed a heavy duty bronze bearing that fixes this problem. Our solid bronze bearing has zero deflection and can withstand the high pressures the pump operates at. Description: 4 Heavy Duty Bronze Bearings Knurled Edges CNC'd To Exact OEM Fitment A fixture and tool kit are available for the installation of these bearings. BRONZE BUSHINGS INSTALLED IN FACTORY PUMP 4 MACHINED BRONZE BEARINGS (LEFT) FACTORY NEEDLED BEARING (RIGHT) SSP HD BRONZE BEARING FACTORY OIL PUMP ASSEMBLY MOUNTING POINT FOR PUMP ASSEMBLY OEM NEEDLE BEARINGS INTERNAL PUMP/GEAR ASSEMBLY SSP |
05-10-2015, 08:41 AM | #3 |
Rep 1,805
Drives: 2014 BMW M5 F10 CP
+1
05-10-2015, 10:22 AM | #4 |
Rep 466
05-10-2015, 11:05 AM | #5 |
Perennial PFC
336
Rep 1,275
Are you able to speculate why Getrag would use needle bearings if a bronze bushing is a better solution? Wouldn't needle bearings be more expensive than bronze bushings for initial manufacture? Or, is the problem mainly with the quality of the needle bearings, not the concept? Thank you.
05-10-2015, 10:12 PM | #6 | |
Rep 466
I am not really sure why Getrag would allow this type of bearing to be used. When you make thousands of pumps, I don't think cost is a factor for any type of bearing choice. The BMW DCT is the only dual clutch transmission on the market that has a part number replacement for the oil pump assembly. I believe that this offered, because they have seen the problem in warranty repairs over the past 6+ years. SSP Last edited by SSPKris; 05-10-2015 at 10:21 PM.. |
05-11-2015, 09:18 PM | #8 | |
Rep 466
Ideally this would be the time to examine the clutch. The clutch could also be replaced at this time. SSP |
05-12-2015, 11:32 PM | #11 |
Rep 466
05-12-2015, 11:39 PM | #12 | |
Rep 466
SSP Bearing installation tool 300.00 If you decide to replace the clutch at this time, we have two options: SSP Stage 1 (14 plate) 2199.00 SSP Stage 2 (16 plate) 2599.00 Please let me know if you have any further questions. SSP |
07-14-2016, 10:09 PM | #15 |
Rep 466
07-14-2016, 10:10 PM | #16 |
Rep 466
