07-01-2016, 08:11 PM | #1 |
Rep 1,300
S63 M5/6 Jb4 questions
Figure I might as well start one.
I have a 2013 bmw M6 and have K&N filters resonator delete and the JB4 + BCM combo. I randomly have issues with the jb4 on map 2. Boost is at 10psi till 5.5krpm then shoots! At 6k Rpm. I guess this could be fuel max etc.. Is anyone else experiencing this? I'm getting a backend ecu flash next week and hoping his should fix it. P.s I ran the revise map 1 and no issues. Map 2 is giving issues. |
07-01-2016, 08:18 PM | #2 |
Hide! My wife's coming!
812
Rep 2,816
Have you posted on N54Tech? Terry with BMS is on there. Post your logs and he can help you out.
07-01-2016, 08:19 PM | #3 | |
Rep 1,300
07-01-2016, 08:59 PM | #4 | ||
812
Rep 2,816
When I had my issues with map 2 it was a faulty BCM. Fixed about replacement. http://www.n54tech.com/forums/forumdisplay.php?f=33
07-01-2016, 10:17 PM | #6 | |
Rep 1,300
07-01-2016, 10:56 PM | #7 |
Rep 788
Yes or run water/meth to add fuel and octane, Terry has posted many times Map 2 is a gamble as some cars (non CP) max out fuel trims so he suggests doing a few pulls and looking at the logs- sounds like you have done this and have the fule trim maxed so your choices are:
CP tune Aftermarket flash Meth injection. |
07-02-2016, 12:08 AM | #8 | |
Rep 1,300
I will be doing backend flash tune next week. Here is my question though.. The last 6 weeks did not have one issue with map and and now out of nowhere bam! This happens like once a month. I guess luck of the draw every time I turn on the car I guess. Anyway if backend flash will fix it that's what it is. |
07-02-2016, 08:43 PM | #10 |
Rep 402
i only run map 2 with 96 octane or better. I also have no meth so you are right on the edge of whats safe for the car.
Also what firmware are you on? 1.5 gave me the same issue, 1.4 I had none so i went back |
07-02-2016, 08:54 PM | #11 | |
Rep 1,300
So I went back to 1.4v and things work. I'm tired of the BS so have appointment for ECU flash next week and done. Will stack with Jb4 |
07-02-2016, 11:31 PM | #13 | |
Rep 1,300
The 1.5V is additive and I don't think it's faster. If you want faster do a backend flash and Bam! |
07-02-2016, 11:42 PM | #14 |
Rep 402
07-03-2016, 10:52 AM | #16 |
Rep 788
07-03-2016, 03:39 PM | #18 | |
Rep 1,300
I'm getting my ecu flashed and will stack JB this Friday and will report back. My advice is to either drive it stock or do a backend flash or a elf I'll ecu tune. Don't risk anything breaking. |
07-05-2016, 04:19 PM | #20 |
IG @bmwF9xG80
3813
Rep 7,593
ARC550 friday before MpactEast you're roll racing Sat?
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
