06-18-2015, 03:44 PM | #1 |
Rep 611
New 285/35/19 front & 345/30/19 rear Car swinging!!!
Hi, I just got my custom rims with 285/35/19 front on pss & 345/30/19 rear on Nitto Nt05r. When going on speed above 140kmh the car would swing to the left & right just like you have turn yr steeling wheel slightly to one either side. The tyres are much thicker & softer compare to stock 265/35/20, 295/30/20 which I have them too but didn't find the way the new sets behave. The last time when I bolt on a set of R888 (285/35/20, 315/30/20) on the stock 20" wheels I also have such experience but not as swinging feel as this current sets. Anyone has the same experience? Don't mind share? Thks
2014 M6 GRAN COUPE FULL HAMANN WIDEBODY.
BR TUNE STACK ON BMS JB4 BCM METH/ UPGRADE SNAIL,ZEX 100 WET SHOT, CUSTOM COLD AIR INTAKE SS DP/ FULL ARKA SYSTEM/ CHARGE PIPE TWIN NOZZ METH/NOS.BC 19" RIMS NT05R 345/30/19 |
06-18-2015, 10:02 PM | #3 | |
Rep 346
any pictures of the car with these wide puppies |
06-22-2015, 09:24 AM | #6 |
Rep 301
Tramlining!
Maybe check the alignment and toe, try decreasing tire pressure to 32psi to see if that is a quick solution..... Here is an article from tire rack: http://www.tirerack.com/tires/tirete....jsp?techid=47 |
06-23-2015, 08:39 AM | #7 | |
Rep 1,805
Drives: 2014 BMW M5 F10 CP
06-23-2015, 11:45 AM | #8 | |
Rep 6,067
Using two different sizes will completely change the dynamic character of your car. With 345 tire, you are adding a lot more weight to the wheels and rotational mass will affect the performance. Also if I'm not mistaken you are using MPSS on front with 300 AA A tread wear/temp/traction rating while the rear tires are 0BB rating. I know you don't need to have the same brand (and rating) on different axles, but front and rear tires of your setup are night and day
06-30-2015, 02:51 AM | #11 |
Rep 175
Another request for pics
2015 M5 6MT Silverstone / Sakhir Orange CP,MPE(Ti Tips),GA1R 20x9.5/10.5(Brushed),KW v3, Dinan Sways, AMS DP's(Catted), Bel StiR+, ALP Quad
