08-10-2016, 03:08 PM | #1 |
Rep 78
BMS Stage 1 2.0,3.5,4.0
Folks, can someone help me out.
I am going to be running BMS Stage 1 for a while until I settle on a proper Full Flash strategy that can accomplish my long-term power goals. Can someone help me understand how to change the boost setting on the stage 1? I have it installed with the Bluetooth app. Do I change from Map 1 to Map 3 to get the higher boost settings? |
08-10-2016, 07:14 PM | #2 | |
Joint Chiefs of Staff
4912
Rep 115,980
Mike |
08-10-2016, 08:00 PM | #3 |
Rep 78
08-11-2016, 10:27 AM | #4 |
4912
Rep 115,980
08-11-2016, 05:10 PM | #5 |
Rep 78
08-11-2016, 06:07 PM | #6 |
24143
Rep 190,707
You should be able to adjust it by changing boost limit in the settings page
08-14-2016, 11:57 AM | #7 | |
I Calibrate Engines
15
Rep 40
Thanks. |
08-15-2016, 12:21 PM | #8 |
24143
Rep 190,707
If you plug the JB4 to a laptop using the USB cable, under settings it should tell you firmware version.
08-16-2016, 09:10 PM | #9 |
I Calibrate Engines
15
Rep 40
Thanks for your response. Would this be a case I have to buy a $35 cable to find out I cannot adjust anything. Or does the JB Stage 1 have other settings I could use the cable for if I have a non-adjustable boost version?
08-17-2016, 12:23 PM | #10 |
24143
Rep 190,707
For the stage 1, the only available setting would be to datalog boost
08-17-2016, 06:48 PM | #11 |
Rep 232
I had a newer version stage 1, and it allowed me to go down in boost, but not up(4psi-3psi). Recently went JB4 w/o boost control for the extra features and maps.
