10-31-2015, 11:36 AM | #1 |
Rep 25
Removing CEL via OBD Tune
About to install Gintani micro catted DP on my 2013 M6 and want to remove the CEL when it shows up. Alex can't code because the dealer installed the latest software. Any other OBD tuners out there who can help?
Shipping the ECU is not an option. |
10-31-2015, 11:47 AM | #2 | |
Hide! My wife's coming!
812
Rep 2,816
m6beast help!! ;-)
11-06-2015, 11:58 PM | #3 |
Rep 1,805
Drives: 2014 BMW M5 F10 CP
Have to benchflash.. That's the way..
11-14-2015, 01:31 PM | #4 |
IG @bmwF9xG80
3813
Rep 7,593
My tuner EnzoPerformance is able to code CEL off with Flash Tune.
But as MCarsFan said it has to be bench flash first but the updates, re-flash etc are done thru OBD2.
60-130mph 6.5s X4M #HCP
60-130mph 5.0s G80 M3 #OrlandoAutowerks Sauce IG: @bmwF9XG80 |
11-17-2015, 05:01 PM | #5 | |
Rep 616
. But, BMS just released their JB4 option now. That will have CEL delete feature as well as you get all the usual JB4 features |
11-17-2015, 07:07 PM | #6 | |
812
Rep 2,816
A flash actually disables the codes related only to the catalytic converter so that the ECU no longer is looking for it. This allows for emissions to pass since the ECU is in ready state. That's how I understood it.
11-17-2015, 07:21 PM | #7 | |
Rep 616
This is same for both flash tunes and piggy back systems. You still will have a CEL if you have a bad ignition coil, EVAP issues, etc. You will not however pass emission testing. Even with a flash tune you will fail. You will have to flash the DME back to stock and re-install the emission items. Same with piggy back. You will have to remove harness and re-install the emission item. |
11-17-2015, 08:00 PM | #8 | |
Rep 1,805
11-17-2015, 08:08 PM | #9 | ||
812
Rep 2,816
JB4 fails from what I've seen since it's just disabling the CEL from displaying on the dash but in reality the CEL is still present in the DME/ECU ther for its not in a ready state and fails emissions. I'm not talking about visual inspections and maybe Texas is diff but as long as it's in ready state it will pass if no other issues are present.
11-18-2015, 04:27 AM | #10 | ||
Rep 25
11-18-2015, 06:32 AM | #11 | |
Rep 514
11-18-2015, 08:14 AM | #12 | ||
Rep 25
In any case.. With the JB4 tune, will this code go away? |
11-18-2015, 10:48 AM | #13 | |
Rep 616
When you connect a diagnostic to your vehicle and look at the emission readiness; the catalytic convertor and oxygen sensor should be read as : Not ready. If not and it shows ready well, that is pretty cool but I have not seen that. Even using Benz, Porsche, BMW software coding it should all be the same type of reading. The JB4 will still show a check engine light if there is an issue, same with flash tune. Example : I had a client with a JB4 come in for a performance issue (CEL ON) also had a ESS flash tune come in for CEL on as well. Both vehicles were F80 M3. I'll have to look into this myself now lol I am flash tuning a 2016 AMG Benz and I'll ask if its different in other states as I have never came across that as I am in cali. Thanks for the information tho |
11-18-2015, 10:50 AM | #14 |
Rep 7,885
This is not an issue for anyone who's registered in South Dakota either. Just sayin'.
But yeah, I think the easiest way to go nowadays if you just want to get rid of the CEL from Catless Downpipes or whatever, is to try to get the new BMS JB4 module. It's a semi-easy installation and can be removed easier before getting an emissions inspection. If you were lucky enough, like I was, to get the original BMS CEL CAN Delete Tool, that thing is straight up plug and play, but since BMS doesn't make them anymore the JB4 is the best way to go. With both the JB4 and the CEL CAN Delete Tool, you will get CEL's related to normal engine malfunctions. Either way, catless downpipes are awesome and the only real way to enjoy these cars as a real M car. This is just my opinion.
11-18-2015, 11:14 AM | #15 | |
Rep 616
Are there or any checks via OBD during inspections ? FYI : Yaphet just moved up North and had the hardest time getting his M5 to pass emissions. His M was only 1-2 years away from being emission exempt too. Saw him the other day when we came back for a cali visit |
11-24-2015, 12:07 PM | #16 |
Rep 228
Does anybody know exactly what the check engine light codes are?
I've had a full ECU tune installed approximately 12,000 miles ago which was supposed to remove the CEL and didn't. I'm still getting "o2 bank slow response- lean to rich" - replicated twice for both cats. Code "12BE08" from bmw, and general code "p013d" and "p013b". What could this be? I'm at shop number SEVEN telling me its the tuners fault after having downpipes, wiring, o2 sensors, spark plugs, all checked. |
11-24-2015, 07:04 PM | #17 | |
Rep 616
Most tuners I have dealt with regardless of the vehicle always want to point the finger away from their own tune. (1 tuning company bench flashed our clients computer with the wrong file.. that took some time for them to believe our diagnostic that they did the mistake) They re-flashed it correctly and all was well after that. With the code, the supplementary information is what is important when reading oxygen sensor faults. The wave path and how it responses. I'll look into the code on my end and see if I have any feed back for you. |
11-25-2015, 07:01 PM | #18 | |
Rep 228
11-25-2015, 07:07 PM | #19 | |
Rep 616
If you are running race fuel or a fuel to damage the sensors then that may be the only possibility aside from a pinched wire which even that would be diagnosed for ohm/resistance testing. I would still send the ECU's to the tuner and have them re-load the software. What tuning company is it ? I'm sure / would hope that they have tuned more then a few with the same setup as you are running. |
11-25-2015, 07:12 PM | #20 |
Rep 228
I wouldn't want to mention their name on here. But it's been recommended to me, and those who have it here and mentioned it don't seem to have the problem. The parameters upgrade itself is definitely there, the power increase is obvious within any gear as is the general smoothness and responsiveness.
Also, I have never put race fuel in the tank. Always use 93. Are you able to find which specific codes should be the ones cleared out? The ones I mentioned are the ones I am receiving and is the reason I am getting the light. |
12-03-2015, 06:52 PM | #21 | |
Rep 616
Your issue is more involved and the diagnostic data is what is needed to figure out your problem. Unfortunately, just the fault code # is not enough from our end here. The operating data is what is needed to help figure out your issues. |
