03-03-2019, 06:01 AM | #1 |
Rep 42
Audio system is soooo bad!
I have the HiFi Professional system and compared to my c63 (Harman Kardon), it sounds so tinny.
What are the best settings? Any help is appreciated |
03-04-2019, 05:00 AM | #2 |
Rep 606
There are a couple threads here that deal with setting up the stereo. I think most threads refer to the B&O system but I would try those for starters.
700_weapon16.00 |
03-04-2019, 09:01 AM | #3 |
Rep 1,250
Drives: 20' X3M CP
You are comparing the HIFI which is the base system to your C63 Harmon?
I had all three, and they are all pretty bad.
2020 X3M CP - IND Reflector set | Ceramic Tint
Retired:2015 M5 CP MSR Intake|Carbon Fiber Fender Vents|Meisterschaft GTC catback with LXR mid pipes and ER Catless DPs | BPMSPORT Stage II Tune | RKP Rear Diffuser and Challenge Center piece |RKP Front Lip| Painted Reflectors | H&R Springs | Strasse SM5R Carbon Fiber Wheels | Nitto R888 | |
03-05-2019, 03:20 AM | #4 | |
Rep 42
S677A HiFi System Professional DSP I didn't know that was the base system?! Either way, C63 system just sounds nicer to me. Iv tried a few different settings too now, it's just not a great system. |
03-06-2019, 05:49 AM | #7 |
Drift Instructor @ BMW Club UAE
310
Rep 433
Drives: BMW F10 M5
S676A HiFi Speaker System
I've got this with Surround and Equalizer option. I cannot complain to be honest but I think it could have been better. For a better experience do the following. In the main sound menu: Treble: +10 Bass: +8 The Equalizer settings (top to bottom) +6 +4 +2 0 +2 +4 +6 Things should be better this way with much deeper bass and clearer vocals. Our speakers cannot handle Mid Range much as I figured. Best way to test this is to listen to some Piano pieces on 75% volume. You'll find that some speakers are being maxed out and will start to rattle. Hence, the lower mid range option is the best option.
F10 M5 - AlpineWhite/SakhirOrange[DCT](Current)
F16 X6 - SparklingStorm/CognacBlack (Current) Follow me on Instagram (Click) |
700_weapon16.00 M5Rick60879.50 |
03-06-2019, 08:58 AM | #8 |
Rep 42
Thanks Rafik, it's improved a little but still not impressed. I think BMW in general just can't compete with Merc or Audi when it comes to audio systems, my old M4 with HK sounded tinny as well. Oh well, will have to live with it
03-06-2019, 04:04 PM | #9 |
Rep 385
I've had a lot of bmws over the years and the hk systems have been pretty bad quality. Usually redo the system. The b&o in the f10 is not bad for bmw and I've not felt the need to rip it out.
03-06-2019, 10:14 PM | #10 | |
310
Rep 433
Drives: BMW F10 M5
You see normal F06 640i with a B&O these days... And the other problem is, BMW's sound system isn't pretty simple and would require an experienced aftermarket company who can do the enhancements and the modifications, which eventually would cost a hell lot of money.
03-08-2019, 11:06 PM | #14 | |
310
Rep 433
Drives: BMW F10 M5
I will take a picture of my current settings today and post them here.
03-11-2019, 12:20 AM | #15 |
Rep 123
03-11-2019, 01:18 AM | #16 |
310
Rep 433
Drives: BMW F10 M5
The OP asked about the best settings to maximize his experience. It's not about the personal matter or taste. Of course your settings might suit you well and each to his own. But replying to the OP, your settings will not serve his purpose.
03-12-2019, 04:26 PM | #17 |
Rep 19,791
Ok but he doesn't know himself what settings to have so our suggestions will help him get closer to what he wants at least.That is what he has asked for.
03-12-2019, 10:57 PM | #18 | |
310
Rep 433
Drives: BMW F10 M5
Cheers buddy
03-20-2019, 04:21 PM | #19 |
Rep 298
The best Settings are those that sound best to you.
With the Logic 7 box ticked, the system sounds excellent. Play around with the equalizer levels, till you are happy. |
05-06-2020, 03:01 PM | #20 |
Rep 19,791
S677 Professional DSP
So I have an unbranded HK system, phew at last I know.
DSP stands for Digital Signal Processor. It has EQ,Surround sound,DAB radio and CD player slot and centre dash speaker. Now just have to find out what type of amplifier nestles in the back. Last edited by M5Rick; 05-07-2020 at 04:41 AM.. |
05-06-2020, 09:54 PM | #21 |
Rep 349
I don't have any experience with the standard or HK systems in the F10, but the B&O needs serious tweaking of the EQ to give its best (sounds underwhelming with the standard EQ settings, and can sound SIGNIFICANTLY better with some tweaking).
I highly recommend you have a bit of a play with the EQ and see if you can get it sounding better to your ears. |
05-07-2020, 08:50 AM | #22 |
Rep 19,791
S677 Professional DSP Amplifier
Found it! Man it took some finding but I know which one I use now.
It's Harmon/Becker BE B103 M Active Sound Design with Dolby Pro Logic 11. |
