      01-27-2017, 10:51 AM   #1
LI-M5
Drives: 2016 M5
Dinan Sway's on Comp Car
So i got a 16 and am about to start getting her all sexx'd up , got her on Halloween and have been stockpiling parts! New one's to some old stuff from my 13 that i traded.. Needless to say the spare bedroom is a like toy store w goodies for Olivia and she's in for break in serv as i type so it's time to get serious!
W that being said how do you guys feel about the $1250 or so installed for these sways? i had em on both of my e60's and made a whirlwind of a diff in body roll and for me its a no brainer , Trevorm3 will say guy its a 4400lb car but i say why not take out as much roll as poss and make her feel like a 3400lb car if poss..
I guess my main Q is Since i have a comp car is the diff gonna be noticeable or does the comp suspension make this upg insignificant?
Thank's Neil
      01-27-2017, 11:18 AM   #2
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
I don't have Comp to Dinan sway bar experience, but did feel a substantial difference when I changed from standard sways on my 2013 M5 to the Comp version. I don't remember reading any feedback from someone who did what you're considering, so if you do change them out please report back.
I'm of the opinion that the front sway has the most effect, so you might try that alone at first to see how it handles? The BMW rear comp sway bar is virtually identical to the standard sway, so I wasted my money on that one.
      01-27-2017, 02:12 PM   #3
carrera2RSL
Drives: F10 M5 CP
I went from Comp to Dinan sways and a notable difference, I run them full hard front and rear
      01-27-2017, 03:10 PM   #4
Used2be
Perennial PFC
Used2be's Avatar
Interesting, thanks. Did you do a progression from full soft to your current full hard setting to feel the differences? I'm happy with the comp bar for street, but something stiffer would be better for track I think.
      01-27-2017, 04:14 PM   #5
LI-M5
Drives: 2016 M5
Originally Posted by Used2be View Post
Interesting, Did you do a progression from full soft to your current full hard to feel the differences? .
Lmao this ^^^^ sound's Borderline ****sexual
      01-27-2017, 04:16 PM   #6
LI-M5
Drives: 2016 M5
Thank's carrerra i think ima do it either way , just wanted some opinions and real life scenario's!
i was plan on run in the middle setting's , i don't want it to over/under steer in cool or wet condition's which i believe a 3rd position setting would create
Neil
      01-27-2017, 09:34 PM   #7
TrevorM3
Drives: 6.3 AMG
ghey
      01-28-2017, 01:41 AM   #8
carrera2RSL
Drives: F10 M5 CP
I like the feel of a car with stiff roll bars always have, I know there is the impact of non independent loading of the other wheel when your are riding on an undulated road surface, But I don't like the feeling of floating gracefully unaware off the road surface undulations, even if the car might be ultimately quicker in some situations - its a 600hp road car so how quick can I actually be legally and tracks are smooth... It's not a rally car !
The turning is improved but the most noticeable difference is when you start to load the car up in corner it feels very taught and refuses to roll. It's not hard in any way, so nothing like changing springs and dampers and if you prefer less roll stiffness you can manually adjust quite quickly to get you preferred settings.
      01-28-2017, 01:42 AM   #9
carrera2RSL
Drives: F10 M5 CP
Regarding the progression from middle to full hard definitely noticeable
      01-28-2017, 11:32 AM   #10
m5 guy
m5 guy's Avatar
Drives: 2020 M5 Comp
Thanks for posting your feedback. The Dinan sways and balls are next on my list. It's nice to hear the sways are worth it even if you have the comp pack.
      01-28-2017, 12:00 PM   #11
Used2be
Perennial PFC
Used2be's Avatar
Years ago when I did the comp sway bar change, I thought the Dinan front bar had three adjustment points, but now I see it has two. Perhaps my memory is bad (very possible) or Dinan decided they only needed two attachment points for what they were after. Thanks for your analysis.
      01-28-2017, 01:25 PM   #12
carrera2RSL
Drives: F10 M5 CP
Rol bar installation isn't too difficult. It was a full day to do the install of the coils and bars, then another 1/2 day to set up. So quite expensive
      01-28-2017, 01:37 PM   #13
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
I did it on my 13 and it made a substantial difference and I've driven several comp packages. I agree that the DINAN swap will make a difference.
      01-28-2017, 03:01 PM   #14
Tanin
Tanin's Avatar
Dinan sways made a drastic improvement on my car with no degradation in ride quality. IMO a must have if you are looking to improve handling.
2015 M5 6MT Silverstone / Sakhir Orange CP,MPE(Ti Tips),GA1R 20x9.5/10.5(Brushed),KW v3, Dinan Sways, AMS DP's(Catted), Bel StiR+, ALP Quad
      01-28-2017, 05:28 PM   #15
LI-M5
Drives: 2016 M5
Awesome info guy's! i was sold pretty much to begin w but just wanted to make sure the comp pkg would'nt 0 out the effect!
i know i've seen 13m5f10 rave about em as he still is so it's a done deal for me , will order on monday from turner most likely!
thank's again
NEIL
      05-08-2017, 04:58 PM   #16
Blkthght
Drives: 2015 F10 M5 CP Singapore Grey
Giving very serious thought to purchasing the Dinan sways for my Comp pack. Actually, I probably will get the sway bars. But the only thing I'm still deciding on is which settings to go with. I have read that the optimal setup is to run the dinan sway bars full stiff in the front and full soft in the rear. Apparently this is the recommended setup by suspension techs and other experts in the field. The dinan sways on their softest setting are already stiffer then OEM CP sways, so I am worried that if I set the rear sway any stiffer that will just cause more oversteer and less traction.
Seeing as how you have them set to full stiff front and full stiff rear, do you have any problems with excessive understeer/oversteer or any problems with losing traction?? Thanks in advance for whatever observations you can share.
      05-08-2017, 05:02 PM   #17
Blkthght
Neil
Any thoughts or observations on your experience with the dinan sways on the CP car?? Noticeable difference?? Any suggestions for the settings? I am also thinking about going medium in front and rear, but I am also considering going soft in the rear to avoid any traction issues.
      05-08-2017, 05:07 PM   #18
Blkthght
Good to know that ride quality is not affected. I was worried about this. What settings do you have your dinan sways on? Also, did you notice any negative effects from the heavier steering that the front sways cause??
      06-06-2017, 12:05 AM   #19
BMWAUDIO
Drives: F90 M5 Frozen Gray , 997 C4S
Are you suggesting dinan sways and not doing the dinan shocks and springs ?
I would think the springs and shocks woudl make a bigger difference than sways on a comp car.
      06-06-2017, 02:37 AM   #20
carrera2RSL
Drives: F10 M5 CP
I ran the both then moved to KW V3 and Dinan sways. I found the Dinan springs very good for compliance and actually more comfortable than stock CP springs. But they are actually marginally softer than CP, stiffer than stock. The advantage is ride height and corner weight adjustment more than Spring weight.
I keep meaning to advertise the Dinan springs 2,000 miles before I went KW V3 (I bought the KW second hand on here - had to try them !)
      06-20-2017, 06:01 AM   #21
E F10 M5
E F10 M5's Avatar
24
Dinan Sways are worth the Money, especially combined with KW V3.
      07-02-2017, 12:17 PM   #22
LI-M5
Drives: 2016 M5
had them install'd finally and could'nt be happier , def a huge diff in stiffness and body roll and makes car all round feel tighter in any mode
if your thinking / debating stop and buy !
