11-25-2016, 06:22 PM | #1 |
Rep 466
BMW DCT Viton Transmission Pan Gasket Package
From the factory the BMW DCT transmission comes with inferior pan gasket seals. Both pan gasket seals overtime leak and make a mess on the underneath of the vehicle.
The only repair form BMW is to replace the factory gasket with another inferior factory gasket. We have sent the factory gaskets to be analyzed by an independent company. We found that the rubber used from the factory is rated to 220-230 F and has a very low resistance to chemicals. We stepped up and have made molds from the factory gaskets. The gaskets now are made from high temp. Viton rubber. Viton is chemical resistant and will withstand temperatures of -70 F to 450 F, which makes them superior to the factory gaskets. We have also replaced the factory aluminum stretch bolts with hardened stainless bolts which can be reused. This package is used to put an end to leaking pan gaskets. Replacement of factory transmission pan gasket and hardware Replacement of factory transmission pan access cover gasket http://www.sspperformance.com/bmw-dc...t-package.html |
11-26-2016, 01:10 AM | #6 | |
Rep 654
Nice
Why would BMW use such an inferior material for a critical component? Cost cutting? |
11-26-2016, 10:21 AM | #7 |
Rep 466
BMW doesn't build the transmission, Getrag does. Manufacturers always cut costs to drive up profits. They install inferior parts so when your warranty runs out, it gives the stealerships tons of business.
11-26-2016, 11:20 AM | #8 |
Perennial PFC
336
Rep 1,274
When your aluminum replacement pan is purchased, is it the Viton gasket and stainless bolts that come with it? How much does the side access pan gasket and hardware cost separately?
11-27-2016, 03:55 PM | #9 |
Rep 466
11-27-2016, 06:05 PM | #10 |
Perennial PFC
336
Rep 1,274
I want to make sure I understand you correctly, when I buy your anodized billet DCT pan for $1,224 you are selling it to me with the inferior factory gasket? Is the mounting hardware you supply with the pan your stainless bolts or the factory aluminum stretch bolts? Thank you for clearing this up for me.
11-29-2016, 07:44 PM | #12 | |
Rep 466
I hope this clarify things. SSP |
11-29-2016, 07:45 PM | #13 |
Rep 466
