03-25-2023, 10:23 PM | #2 |
Fueled by Recycled Dinosaurs!
632
Rep 1,172
Drives: F06 M6
Nice! I wont have access to my car or BM3 for a couple of months but sincerely hoping this is legit.
fstm5145.50 |
03-26-2023, 02:05 AM | #3 |
Rep 280
04-02-2023, 07:59 PM | #4 |
Rep 112
I’m running it. I’m putting just about 6 gallons of e85 then filling the remainder of my tank up with 91 when I have 1 gallon left or around 10 miles left according to the gauge.
I am really impressed with it. I had just installed new tires the same day I flashed that e30 map about a week ago and I was thinking wtf these fuckin tires suck I can’t catch any traction in 1st, 2nd nor 3rd unless I’m going dead straight on a perfectly smooth road with a little bit of heat in the tire otherwise if all of those things aren’t perfect 3rd just lights em up nearly as bad as second. Then I realized it wasn’t the tires that sucked it’s just that e30 map is making so much more power compared to the OTS Stage 2 91 map At least according to my butt dyno. But the fact that it is just spinning 3rd like that helps confirm the butt dyno in my head at least lol. Anyone thinking about running it I would say do it, it’s a no brainer if you have an e85 station near you then I suggest flashing it you won’t be disappointed. |
fstm5145.50 |
04-02-2023, 08:03 PM | #5 |
Rep 112
I recently filled up a 6 gallon jug of some 102 or whatever the highest octane they have at this sunol gas station in the South Bay here in CA and I want to run the car just about empty fill it with that jug and flash that OTS race gas map. I’m curious if anyone else has tried that map and how much more power it has then the normal stage 2 91 map
04-02-2023, 08:39 PM | #6 | |
Rep 280
If you can grab some 60-130 times and post it that would be great |
04-03-2023, 09:52 AM | #7 | |
Rep 7
are you still running this ots map? I just saw this as well and on the fence . Currently running stage 2 91 and happy but always looking to make some extra power . Any issues yet ? |
04-03-2023, 12:11 PM | #8 |
Rep 280
No I still have not ran this map, I’m still on the ACN map which is great but I feel like extremely limited.
04-05-2023, 02:21 PM | #9 |
Rep 112
I am still running it with no problems. From the logs I’ve done it looks like it’s all good. I’ll post one up here shortly if you want to take a look at them. I mean I’m no expert at reading the logs though so hopefully someone here can let me know if something doesn’t look right.
fstm5145.50 |
04-05-2023, 02:22 PM | #10 | |
Rep 280
Any videos of a pull ? |
04-05-2023, 02:33 PM | #11 | |
Rep 112
04-05-2023, 02:34 PM | #12 |
Rep 112
I need to get a draggy so I can do some 60-130’s. But I can do the next best thing and use my GoPro on the gauges thag way you can at least get a visual of what it looks like. I’ll go warm up the ole M5 right now and take it for a quick spin.
fstm5145.50 |
04-05-2023, 02:36 PM | #13 |
Rep 112
I’ll also try and take some more logs with actually revving the thing out. I don’t usually rev it out unless I’m actually racing someone because it seems like that’s what would do the most damage and wear to the motor.
fstm5145.50 |
04-05-2023, 02:38 PM | #14 | |
Rep 280
Here is my 60-130 run I did the other day, could have done better, had to change lanes etc but Still on the 91 ACN stage 2 https://streamable.com/t3yzx5 |
04-05-2023, 02:39 PM | #15 | |
Rep 112
04-05-2023, 02:44 PM | #17 |
Rep 112
Ohh ok. Yeah I might actually order the draggy right now then, since that’s a great way to see what the different maps do in the car. I would try flashing the regular 91 map or that e30 map I haven’t had any issues the computer is able to adjust things if it’s not completely right. Like I filled my car up with the 6 gallons of e85 when I had only about 2 gallons in my tank and the 91 was so expensive at the gas station I got the e85 at that I decided to drive a couple miles to the other chevron closer to my house that was like $0.75 cents a gallons cheaper and the car ran fine with even that much e85 now I wouldn’t suggest doing that it just shows it’s able to compensate quite a bit with the computer. So if you were to run the normal 91 map or the e30 map I’m sure you’d be fine.
04-05-2023, 02:50 PM | #18 | |
Rep 280
04-06-2023, 04:17 AM | #19 | |
Rep 178
04-06-2023, 02:00 PM | #20 |
Rep 280
04-06-2023, 02:02 PM | #21 | |
Rep 280
04-07-2023, 02:27 AM | #22 | |
Rep 112
I’m on stock turbos, if it was making 36lbs of boost my rods would have still been on the street after that pull lol |
