      05-13-2013, 12:01 PM   #1
krown
krown's Avatar
29
Drives: 2017 Alpina B6
Door lock settings keeps changing
I have tried to set the doors to automatically lock once the car is in drive. Once the box is checked, it will be fine for a few days, then the box is unchecked in the Settings Menu and it will revert back to doors being open while I drive. I will then have to set it again. This is getting damn annoying.. can anyone help me out?
      05-13-2013, 12:06 PM   #2
AGS
AGS's Avatar
499
Drives: 2022 M5 Competition
Any chance you're alternating keys? The settings are remembered for each key. If you set them for key #1 and then accidentally grab key #2 one day all the settings will be different.
      05-13-2013, 12:29 PM   #3
krown
krown's Avatar
29
I thought of that, and my wife uses key #2, but wouldn't the setting revert back when I use my key?
      05-13-2013, 12:51 PM   #4
AGS
AGS's Avatar
499
Yes, it should. If you're using the same key and settings keep changing, sounds like a software bug. Maybe try having the dealer reprogram the car to see if it corrects the bug?
      05-13-2013, 01:01 PM   #5
avlnch
Drives: 2013 Individual M5
When you are using the second key, ensure that a different profile is selected. If not, change it. You should only have to change it once and from there on out the keys will be using separate profiles.
Worth a try..
      05-13-2013, 04:11 PM   #6
krown
krown's Avatar
29
How do you change the profile on a key?
      05-13-2013, 04:17 PM   #7
jmh
Internet Crash Test Dummy
jmh's Avatar
You create a profile in your iDrive and it will be associated with the key used to open the car
Once you've created one for the first key. Lock the car and open it with the second key and create a second profile using a different name
You can also use the online profile manager to modify/change settings once you've done the initial setup. http://www.bmw.com/com/en/owners/navigation/pia.html
You can also transfer profiles to other BMWs (loaners etc)
      05-13-2013, 04:39 PM   #8
bm5bullit
bm5bullit's Avatar
Drives: 2021 BMW M340i
Good to know, my car was doing the same thing. Thought the car was developing Alzhemimer's.
2021 M340i
2020 X3 M40i - her car
      05-13-2013, 05:32 PM   #9
krown
krown's Avatar
29
Thanks. Will try and see if it works!
      05-13-2013, 05:38 PM   #10
avlnch
@jmh gave the correct information regarding profiles.
To get to the profiles menu:
Settings -> Profiles
To rename a profile:
Highlight the profile you want to rename (for example highlight the checked profile that's probably named "------" and then move the iDrive controller right to access the options menu, then click Rename.
Give that a try and I'm sure that will rectify the car memory issue your having. check back in and let us know if it worked.
      05-14-2013, 11:55 AM   #11
krown
krown's Avatar
29
Ok. I renamed it so hopefully things will stay as is for now.
Thanks for the help!
