09-12-2014, 05:14 AM | #1 |
Rep 611
Any tuner out there can upgrade our rear differential for better 0 to 130 timing?
Hi Guys, anyone with any experience on our rear differential upgrading for better 0 to 130 timing? I believe we have our gear ratio at 3.15 & any chance we can replace with a 3.62 or something else to improve on the lower speed range for 1/4mile timing?
I know there will be more wheel spin n problem on low gear gripping but just wanted to explore to see whether anyone with similar experience even with the few older M model (E39, E60 M5) Any advice will be appreciated, thanks. Andy
2014 M6 GRAN COUPE FULL HAMANN WIDEBODY.
BR TUNE STACK ON BMS JB4 BCM METH/ UPGRADE SNAIL,ZEX 100 WET SHOT, CUSTOM COLD AIR INTAKE SS DP/ FULL ARKA SYSTEM/ CHARGE PIPE TWIN NOZZ METH/NOS.BC 19" RIMS NT05R 345/30/19 |
09-14-2014, 05:13 PM | #3 |
Rep 6,067
09-14-2014, 05:35 PM | #4 |
Rep 4,106
Why don't you maximize the potential of the car as is? What times are you trying to improve?
What did you hit 1/4 mile?
09-14-2014, 06:37 PM | #5 |
Rep 611
We always got drag race in our own group, just find that our car's power isn't as good after 4th gear. Maybe is bcos the other cars that we r racing has much bigger turbo (fully mod evo9 about 700whp) 1st to end of 3rd gear the M is still on par, after I enter into 4th gear the evo will slowly pull away. So looking for something higher differential eg maybe 3.91 to improve timing, any further advice guys??? Thanks
09-15-2014, 09:02 AM | #6 | |
Rep 2,176
09-15-2014, 09:34 PM | #7 | |
Rep 1,417
09-15-2014, 10:44 PM | #8 | |
Rep 646
The only thing I would add is that changing the differential on a high tech toy like the M5 may also necessitate software updates. People changing the tires (drag radials) which isnt all that different tire height, still get weird error codes popping up. I would imagine the DCT software may not respond well to the change in hardware. |
09-15-2014, 11:36 PM | #9 | |
Rep 611
09-16-2014, 07:36 AM | #10 |
Perennial PFC
336
Rep 1,275
I agree completely with gmd2003. The final drive gearing in the differential will not change the pull of the motor in the upper gears, that is all motor and the way it makes power. Look at the gearing of our DCT with our differential gearing versus your friend's C63 trans and diff gearing. Perhaps the transmission gearing of the Mercedes allows him that enhanced pull from 4th on? The differential gearing wouldn't do it.
09-16-2014, 09:00 AM | #12 |
Rep 611
09-16-2014, 10:32 AM | #15 |
Rep 611
09-16-2014, 10:34 AM | #16 |
Rep 611
09-16-2014, 01:34 PM | #17 |
Rep 1,576
Each gear has an individual ratio, you could open up the gearbox and just change the ratio of the those 3 gears. You can find the current ratio of each gear online, and then change it slightly to have a shorter gear.
09-20-2014, 05:46 PM | #18 |
Rep 611
[QUOTE=shahano;16642762]Each gear has an individual ratio, you could open up the gearbox and just change the ratio of the those 3 gears. You can find the current ratio of each gear online, and then change it slightly to have a shorter gear.[/
Thanks for the info, do u think by replacing the gear do we need to reprogram the software of the DCT? |
