07-14-2017, 02:22 PM | #3 |
Rep 442
Its the $3500(paid less than a 1/3 of that) Dinan stage 2 set up that plugs into the computers(Or DMEs?).
Not sure if its a piggy back though... Totally different connection locations from the jb4... so I wonder. |
07-14-2017, 02:47 PM | #4 |
Rep 5,233
Piggyback.
07-14-2017, 03:49 PM | #5 |
Rep 2,062
Still paid too much for what's notoriously conservative compared to others, but yes, it's a piggyback...a flash is completely different.
07-14-2017, 06:38 PM | #6 | |
Rep 442
PLUS The BCM worked like crap and didn't do anything but hurt the power. So I am running a super expensive JB4 BCM/ - BMC. Basically stage 1. So I assume the stage 2 dinan will be as good as the jb4 stage 1... yes? Hopefully.... |
mister2d155.50 |
07-14-2017, 07:10 PM | #7 |
Rep 2,062
I went from stage 2 Halim/HC Performance flash only to stacked with JB4/BCM and each step has been a great improvement. Logging has helped resolve a maxed trims issue as well as misfires at higher boost, which was resolved with colder plugs and tighter gaps.
07-20-2017, 03:10 PM | #8 | |
Rep 598
Lerxst M4142.00 |
07-25-2017, 05:05 PM | #9 |
Joint Chiefs of Staff
24186
Rep 190,781
You should not ever run 2 piggybacks at the same time
07-25-2017, 05:56 PM | #10 |
Rep 442
Right. Got it.
Not running both. I will say this... Doesn't the jb4 trick the car to run higher boost? Doesn't the Dinan change the Air/Fuel ration via ECU tune? They both change performance in 2 different manners. Dinan- Plugs into ECUs.. JB4- Plugs into the intercooler(Right?) So as I said I am not running both... Still running the JB4 at this time... until I upgrade the Dinan. But they both change the engines performance in totally different ways. So I still wonder. But yah yah... not gonna do both. Last edited by Rockin-The-F10; 07-25-2017 at 06:01 PM.. |
07-26-2017, 07:04 PM | #11 | |
Rep 402
07-31-2017, 12:25 PM | #12 | |
Rep 598
Lerxst M4142.00 |
07-31-2017, 12:47 PM | #13 | |
Rep 442
The entire reason I asked the question. After watching the video I see that dinan also tricks for more boost but does it differently. Anyhow.. as I said, I am not going to try to run both. That would be pretty stupid. I obviously understand that is not an option and will not. |
