05-22-2014, 04:39 PM | #1 |
Rep 6,125
New Products form Dinan (Intake and Suspension system)
I just received email form Dinan about new Intake and suspension.
Intake is very pretty but priced 3k and height adjustable sprint kit 1.5k Information from their website: http://dinancars.com/product/d760-00...ries&mid=1163/ Dinan® Carbon Fiber Cold Air Intake for BMW F10 M5 The F10 M5 Dinan carbon cold air intake, like most Dinan products, has a sleek and functional appearance that embodies high performance. The F10 M5 cold air intake allows cool outside air to be pushed into the engine via a pair of supplemental carbon fiber intake ducts located at the front of the engine bay. The M5 cold air intake system was carefully designed within tight packaging constraints and in consideration of ideal aerodynamic diffusing angles to optimize the efficiency and performance of this induction system. Each duct leads combustion air through a custom designed intake assembly that has a larger than stock metered air flow housing, as well as a Dinan conical air filter with a 77% larger capacity. Dinan engineers have painstakingly developed custom tooling to ensure the entire Dinan cold air intake system is sealed like a factory replacement, thereby preventing hot air from the engine compartment to compromise its effectiveness. The stock air inlets are left intact and fully functional to provide a new total of four air intakes into the engine for maximum airflow. Improved induction airflow offered by Dinan cold air intake systems increase engine performance, even more so if used in combination with other performance enhancing Dinan products. The F10 M5 Cold Air intake is in compliance with U.S. EPA Memorandum 1A, or this product has not been found, nor is believed to be, unlawful for use under the provisions of the Clean Air Act. Currently: This product is not legal for sale or use in California, or states that have adopted California emissions standards, on any pollution controlled motor vehicles. Benefits of Dinan's F10 M5 Cold Air Intake: • 627 HP and 616 lb-ft of Torque when combined with the D-Tronics Performance Tuner and exhaust. A difference of 17 HP and 11 lb-ft of torque from Dinan Stage 1 (D-Tronics Performance Tuner Only). • Dinan proprietary Injection molded Dinan MAF housings are larger than stock • Stock air filters are replaced with 77% larger Dinan conical air filters. • Entire Dinan Intake system is sealed like a factory replacement to ensure only cold outside air and not hot air from the engine compartment is being utilized. • Stock System Stays Completely Functional • Carbon fiber air box lids and intake ducts • Raised Dinan logos are laminated into the carbon fiber intake • Rubber hoses, mountain brackets, & hardware included.
PAST: F80 M3 ZCP | 911.1 C2S | F10 M5 ZCP | E70 X5M | E90 M3 | E46 M3 | E36 M3 |
05-22-2014, 04:41 PM | #2 |
Rep 6,125
http://dinancars.com/product/d190-10...ies&mid=1163// Dinan® High Performance Adjustable Coil-Over Suspension System Product Description For the driver that demands the best out of their vehicle. The Dinan® Adjustable Coil-Over Suspension was bred in the race lab but refined on the street for maximum versatility. No matter the environment, the traction that is bestowed upon the vehicle from the improved suspension will inspire new found confidence when running at higher speeds. Combined with a substantial reduction in body roll as well as reducing dive under breaking and squat under acceleration. Dinan will guarantee you superior handling, performance, and comfort. Dinans design keeps the factory Electronic Damper Control shocks in place and implements threaded collars to allow the user to change the ride height. The end result is a sleek lowered stance that provides improved handling to go along with its stunning visual appearance. The springs combined with progressive bump stops and other components increase travel that allows the car to be lowered up to a 1.25”. Suspension packers are included to fine tune handling and comfort by changing the clearance of the progressive bump-stops, something no respectable racecar is without. Components are machined from 6061-T6 aluminum and black anodized for appearance and corrosion protection. Benefits of Dinan’s Performance Coil-Over Suspension System: • Threaded collars allow easy and precise front & rear vehicle height adjustments. • Up to 1 1/4” of lowering is possible depending on tire clearance although ¾” drop is recommended to maintain ride quality. • Spring rates are 15% stiffer for both front and rear. • Substantial reduction in body roll. • Included suspension packers allow adjustment of bump-stop clearance to fine-tune handling and comfort. • Dinan-spec progressive bump stops improve ride quality at lowered ride heights. • Components are machined from 6061-T6 aluminum and black anodized for a sporty appearance as well as corrosion protection. • Compatible with BMW EDC shocks.
05-22-2014, 05:31 PM | #3 |
dentite
339
Rep 759
Drives: 718 GT4, M2C, JLU392, e92 M3
I'm going to get both of these. I believe they're priced right taking into account the Dinan and M5 tax.
I wonder when the tune will be out? |
05-22-2014, 07:49 PM | #4 |
Rep 2,245
Suspension seems reasonably priced and keeps EDC, I might be interested.
2016 991.1 911 Carrera GTS
05-22-2014, 07:53 PM | #5 |
Rep 7,885
The tune will be out very soon. The intake design is very interesting and is the first I've really seen that has the potential to really increase performance. Don't know about the new Coilovers from Dinan though. KW just released theirs and depending on the price of the Dinans the KW may be a better choice. The KW's go for about $1,100-1,200.
05-22-2014, 07:59 PM | #6 |
Rep 672
Drives: M2 Comp
Garage List 73 911 RSR [0.00]
04 996 Cup [0.00] 06 997 Cup [0.00] 12 Boxster Spyder ( ... [0.00] 15 Sierra HD Denali [0.00] 16 GT3RS [0.00] 17 Radical SR3 [0.00] 18 Model X [0.00] 18 GT350R [0.00] 19 M2 Comp [0.00] |
Tune is another piggyback, though claims to take more that boost into account.
05-22-2014, 08:04 PM | #7 |
Rep 6,125
I wish they made their intake in plastic and lower the price. with 3k, I'm sure I can buy a full titanium exhaust from HKS for JDM rides. =D
05-22-2014, 08:36 PM | #10 |
Rep 6,125
This is from Dinan website:
Product Specifications Labor Hours/Installation Hours: 6.00 Required Items: Installation requires specialized Dinan® tool kit. What the hell is specialized Dinan tool kit?
05-22-2014, 11:29 PM | #11 |
Rep 4,106
It comes with a dinan badge
05-22-2014, 11:32 PM | #12 |
Rep 4,106
Heard of another Switzer tune on a M5 going into limp mode today after several m5's took a major poop with ETG tunes pushing too much boost.......hmm two years later and no issues with BMS.
05-23-2014, 09:11 AM | #13 | |
Rep 646
05-23-2014, 09:57 AM | #14 | |
Rep 4,106
What other cars do you know that will lose power from an intake and gain only 5-10hp from a $8k exhaust on a car with forced induction. I ran a 11 flat with stock intakes and they are staying stock, so I completely agree with you Tom. On a different note, how do you like the SQ5? Performance figures for small suv are pretty nice.
05-23-2014, 10:19 AM | #15 | |
Rep 806
05-23-2014, 10:57 AM | #16 | |||
Rep 7,885
05-23-2014, 11:04 AM | #17 | |
Rep 6,125
05-23-2014, 05:18 PM | #18 | |
Joint Chiefs of Staff
4912
Rep 115,980
