06-26-2017, 04:08 AM | #1 |
Rep 634
Misfire ?
So I was driving on freeway going 85 mph on 3rd gear... power started to cut out and car went into limp mode. Pulled over and turned off car , and turned it back on. Car has driven fine ever since. Anytime I've had this issue happen, there's usually been a faulty coil or spark plug... but usually the limp mode will come back often. It hasn't come back ever since the first time it happen. So I guess what I'm asking is can your car misfire without an actual spark plug or coil not needing to be replaced?
06-27-2017, 05:23 PM | #2 |
Rep 3,622
That's what I would guess. Unless a tune caused the error thencar was reset
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, MPBBK, HRE FF04 Instagram: @brandons340i |
06-28-2017, 04:55 AM | #4 |
Rep 5,233
No codes?
06-28-2017, 04:18 PM | #7 |
Rep 5,233
That will provide you with some answers; you can pick up a code scanner very inexpensively that will provide good data.
06-28-2017, 06:37 PM | #9 | |
3387
Rep 7,541
I'm at almost 15k on original plugs, no issues to date. Tuned since 100 miles.
06-28-2017, 10:55 PM | #10 | |
Rep 1,300
Can never be to cautious with these cars |
06-28-2017, 11:54 PM | #11 | ||
Rep 634
06-29-2017, 12:14 AM | #12 | |||
Rep 1,300
06-29-2017, 05:48 PM | #14 |
3387
Rep 7,541
I think 20 to 30 for a tuned car is a safe bet. I don't use meth, octane booster, or any of that kind of stuff - this may reduce interval mileage.
I recommend replacing with NGK plugs, the stock Bosch plugs I've seen have issues with the ceramic and blow by with less than 2K miles of use.
06-30-2017, 07:14 AM | #16 | |
142
Rep 639
2018 F82 M4 ZCP
2015 F13 M6 ZCP (gone) 2013 F10 M5 (gone) 2008 E90 M3 (gone) |
07-02-2017, 10:53 AM | #17 | ||
Rep 587
yes Mike pls , i just replaced w Bosch in a brand new car w 3400 miles after 1k w jb4/bcm and i'd like to have a set of these on hand after hearing what you just wrote.. Thanks |
07-05-2017, 05:09 AM | #20 |
3387
Rep 7,541
