07-15-2012, 12:34 AM | #1 |
///M
Rep 12
F10 M5 Launch Control
Is there a video that demonstrates how to active Launch Control Mode
also, how harmful is it to the car, is it covered under warranty, how many times can I use it in the lifetime of the car or clutch Does it void the BMW Ultimate Service Package? |
07-15-2012, 07:31 AM | #2 | |
Rep 1,312
07-16-2012, 11:34 AM | #4 |
Rep 4,488
Does it not work the same way as the M3? On the M3, launch control isn't disabled until the 1200-mile service, it's just not recommended (neither is running in the harshest shift mode). But if you haven't already, try the M3's launch control sequence:
- DSC completely off - Shift setting at most aggressive manual setting (there's a higher shift setting only available with DSC off on the M3) - Bring car to a stop - Hold shifter in the forward (downshift) position until you see a checkered flag in the cluster - While continuing to hold shifter, floor the throttle - Adjust launch revs if desired using the cruise control stalk - Release the shifter to go. The car will handle shifting (despite being in manual mode) as long as you keep the accelerator floored. To cancel launch control before you launch, release the throttle before the shifter. As for the other questions, yes it does put a substantial amount of shock into the driveline, and BMWs aren't really meant to take that on a constant basis (unlike cars such as Mustangs, Camaros, Challengers, etc), which is why after you perform a launch you have to drive a few miles before you'll be allowed to do again. It definitely won't void your warranty since it's a feature of the car, but I can't speculate on how much wear it will add to the clutch and tranny in terms of specific mileage reduction before issues/required service.
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 07-16-2012 at 01:22 PM.. |
07-20-2012, 02:44 PM | #6 |
Internet Crash Test Dummy
331
Rep 1,055
Just for completeness
During the first 5,000 km/3,000 miles the launch control should not be used.The 2,000 km/1200 mile pre-delivery check must be performed and reset/confirmed with ISTA (do not reset via the instrument panel service function as the launch control is not released). Preconditions In order for the launch control to be activated the following pre conditions must be met: 1. The vehicle must be stationary, the engine running and be at operating temperature (about 10 km/ 6 mile warm-up drive.). 2. The dynamic stability control is deactivated. 3. The sequential mode and the third Drivelogic driving program are selected. 4. The brake pedal is pressed gently using the left foot. 5. The M gear selector switch is pressed forwards in the direction of travel and held there for steps 6-8. 6. In the M instrument panel a flag symbol must appear (if not, check steps 1-5). 7. The accelerator pedal is fully pressed and remains pressed. An engine speed of about 3,500 rpm is set, which can be increased an additional 500 rpm's by using the cruse control speed button. 8. The left foot is then removed off the brake. Activation Launch control can be activated by releasing the gear selector switch that was pressed to the front. The vehicle is then accelerated. Effect • The launch control starts up automatically using the shortest possible shifting times, up to 5th gear as long as the driver keeps the accelerator pedal fully depressed up to a maximum time limit of 22 seconds. • The start flag icon in the instrument panel remains active during launch control. Automatic Deactivation • The driver leaves vehicle or the accelerator pedal full load range during acceleration or the acceleration phase reaches a duration of 22 seconds. • If one of the preconditions are not met launch control is not possible. • If the gearbox oil temperature is too high (e.g. repeated launch control or start-up similar to a race), activation is blocked until the oil temperature is in a acceptable range. • For each deactivation the start flag goes out and the automatic start-up is cancelled.
15 F10 M5 Individual / Brilliant White / Extended/Full Cohiba Brown (Exec/Driver/B&O/20") / A few Euro add-ons / Stealth K40 / Upgraded B&O / ///M Performance Carbon Interior Trim / IND / Akrapovic Evolution Exhaust / HRE S107 |
02-06-2013, 02:21 AM | #7 |
Rep 6
Thanks to jmh,
I have been looking for instructions in activating the launch control. I can't wait to try this on my car, although I need to wait for probably another month to reach 5000km.... (only has 3700km right now)! Last edited by johnwu1125; 02-06-2013 at 02:40 AM.. |
02-06-2013, 02:55 AM | #8 | |
Rep 567
second worst is mercedes. best is porsche. |
02-06-2013, 06:53 AM | #9 |
Rep 991
Drives: E92 335, W463 G55
Useless? In what sense? Its a bit mental in the activation procedure department, but the effects are quite stunning!..... I would say.
02-06-2013, 03:20 PM | #10 | |
Rep 565
MindlessMark07 ///2013 M5 Alpine White/Black,Orange County CA\\\ |
02-06-2013, 04:27 PM | #11 |
514
Rep 1,437
Mark, Ive tried the procedure to the letter as stated in the manual but to no avail. I must be doing something wrong. I know its a bit different than I was used to from my M3 but I just cant get it. I only have 1700 miles on my car. Is it supposed to work after break in service or do I still have to wait for 3k miles or something? I think I read that 3k number somewhere. I feel moronic. Im usually quite savvy with this kinda stuff.
2022 Individual M5 Comp
Venetian Violet 2021 X6M Comp 2024 i4 M50 on order IG @purpleM5Comp_NY |
02-06-2013, 04:45 PM | #12 | |
Rep 565
I'll try to make a video this weekend and post.
02-07-2013, 06:16 PM | #14 | |
Rep 567
it just has too many damn steps!!! 8 steps! are you serious? by the time you get it activated the other guy will be long gone. especially if you're at the drag strip. even if you have m mode set to eliminate steps 1-3. there's still 5 steps!! i'm not saying it doesn't work, its just way too complicated. then there's the owners manual stating "don't use launch control too many times" its saying in a roundabout way that you are causing damage by using launch control. at least the mercedes race start has no limit, you can use it over and over again, and it will not hold you out after a certain number of starts. still cumbersome as hell to use, but no risk of damaging your engine / transmission. |
02-07-2013, 07:33 PM | #15 |
Rep 1,314
I've had the checkered flag come on but did not execute. I tried to initiate it another day and could not make it happen. I met all the requirements. Unless the car was not warm enough due to it being winter. I was driving the car for over 30 miles. Maybe exterior temp?
02-07-2013, 08:03 PM | #16 | |
Rep 567
even when you do everything right it just doesn't always work. its happened to me too. its inconsistent and finicky that way, as i was saying just a very poorly executed design by BMW. |
02-07-2013, 08:08 PM | #17 | |
Rep 3,041
Way easier on the E60. |
02-07-2013, 08:10 PM | #18 | |
Rep 567
02-07-2013, 08:15 PM | #19 |
Rep 3,041
It was similar. DSC off, S6, hold shifter forward and press throttle and release to launch. Similar steps but on the E60 I could actually get it to work. :-) F10 so far no luck! BOTH cars way too many steps. Needs a stinking "launch" button.
02-07-2013, 08:21 PM | #20 | |
Rep 567
totally. but really, since they flat out tell you in the owners manual to not use it too man times... its basically useless anyway. knowing this, are we really going to be going around "practicing the launch control" when we know it will be damaging the car? its seems like they just put it in there as a gimmick, something for people to have and try it once or twice, just to say, "yeah i tried it". its there. but its essentially useless. takes too long to activate. plain and simple. anyway, i think you all know how i feel about it. so im done. |
02-07-2013, 08:23 PM | #21 | |
Rep 3,041
02-08-2013, 07:38 AM | #22 |
Rep 1,520
Fwiw, you can preset those settings for the M2 button so all you have to do is push M2 twice , hold the shifter and brake and your ready to go.
If you get used to it you can have it ready in a couple seconds. |
