03-21-2013, 12:15 PM | #1 |
Rep 434
What tire size for 21" Wheels
I'm debating whether to go 305/25/21 or 295/25/21 in the rear. My concern is a combination of asthetics, ride quality, and performance. I know some members on this board are running 295s and some 305s. With an H&R drop, what are your thoughts on the size of the tires? Thanks in advance.
03-21-2013, 12:19 PM | #2 |
512
Rep 1,437
Depends heavily on your offsets and type of tire you plan to run.
2022 Individual M5 Comp
Venetian Violet 2021 X6M Comp 2024 i4 M50 on order IG @purpleM5Comp_NY |
03-21-2013, 12:30 PM | #3 |
Rep 434
03-21-2013, 12:37 PM | #4 |
Rep 1,548
Michelin has the 305/25/21 PSS listed as a smaller total diameter than than the 295/25/21. Is that possible?
CURRENT:
His: Porsche 991 Turbo S Carrera white/Black Hers: BMW X3MC BSM/Black |
03-21-2013, 01:31 PM | #5 | |
Rep 852
Link to Tire Rack: http://www.tirerack.com/tires/tires....5&autoModClar= This could also play a role in determining tire diameter based on deflection. |
03-21-2013, 02:09 PM | #6 |
Rep 434
I know many people who have 21" wheels are driving 265s in front and 295 or 305s in the rear. Would there be an issue if I have a set-up of 255/295? Thanks again. Some posts were way too technical for me. I'm a lawyer and not an engineer. hahaha Thanks and keep them coming.
03-26-2013, 05:58 AM | #7 | |
Rep 563
10-26-2014, 12:34 PM | #8 |
Rep 687
I can't decide on wheels to buy 20" or 21" ???
I'm scared if I go with 21" I might lose performance.... What do you guys think ???? If you have 21" wheels please leave you feedback on your experiences |
10-26-2014, 05:40 PM | #9 | |
Rep 68
Is this a toyo T1R you're referencing? Be careful because they're not XL load rated, which is a factory spec. I have been trying for months to get a 305/25/21 setup, but Michelin discontinued them, and Tire Rack is reporting that Pirelli is on back order until Feb 2015. I'm currently looking for other options too, but I just can't find any. Ben |
05-02-2015, 03:02 PM | #10 |
2134
Rep 1,834
Drives: Many, BMW.
Anyone ever ran or seen 305/30/21 or 295/30/21 on a 11.5"? Any fitment issues?
05-16-2015, 09:31 AM | #11 |
mrainv23
30
Rep 224
The load rating is significantly under when you run 255s and 295s on a 21" wheel. Curb weight is fine but when driving aggressively the weight shifts and can cause a blow out. I recently ran into this issue on my M6 and was fortunate to locate a set of michelin pss 265/30zr 21 and 305/25zr 21 setup. I confirmed this with BMW, tire rack, and discount tire. They would not mount the pirellis on my car due to liability.
2014 BMW M6 Gran Coupe F06/M Performance Black Grille/20% Tint/ Exec Package/ Driver Assist Plus/ Black on Black
Sold-BMW 550i F10/Dinan S3/ Eisenmann Race Exhaust/ Vossen CV3s |
05-22-2015, 07:44 PM | #12 |
685
Rep 6,854
We ran the 255/30 front and 295/25 rear in a Yokohama Advan Sport tire, and the fitment was pretty dead on, with our particular offset the 305 wouldve definitely had issues.
The main problem right now in these sizes is availability, Michelin has been on a national backorder for a while now.
Travis Williams
Shop ALL BMW G80 | G82 Parts Here! 480.966.3040 ext 318 Travisw@vividracing.com PM, Email, or Call Directly for aggressive BMW Member Pricing |
05-23-2015, 10:45 AM | #13 | |
Rep 1,805
Drives: 2014 BMW M5 F10 CP
05-23-2015, 12:33 PM | #14 | |
Rep 6,066
If that's the case then you should be fine. The only concern about your setup is the 305 mm tire on 10" rims that we already discussed, but I recall you mentioned that you emailed them and they gave you green light...
05-23-2015, 07:27 PM | #15 | |
Rep 1,805
12-29-2015, 09:01 PM | #18 |
Rep 327
Bump.
I purchased some Morr 10.2 21" wheels. 9.5f/11r. My car has an ecu tune, dps, and intake, so I'm looking for the best combination to gain traction. Could I run 275/315 setup? |
