      06-06-2021, 05:56 PM   #1
Dinan M6
Drives: BMW M6
2013 M6  [10.00]
Rattle/Buzz in M Sport Steering Wheel Solved!!
Here it is! I figured out the problem with the M Sport steering wheel. This steering wheel is on the 3, 5, 6 Series and probably a few other cars. There is a rattle or buzz that occurs while driving on rough surfaces and goes away on smooth road. It drove me bananas for a long time until yesterday. I road tested my vehicle and the noise is gone. I put together a tutorial to fix the problem and attached it to this post. Feel free to repost this anywhere you think it may help someone.
https://drive.google.com/file/d/1WwO...ew?usp=sharing
      06-07-2021, 04:14 PM   #2
arucano
arucano's Avatar
2014 BMW M6 GC  [10.00]
link does not appear to work
F06 M6 Grand Coupe CP
Sapphire Black Metallic
The drive is the destination
      06-11-2021, 06:07 PM   #3
Dinan M6
Drives: BMW M6
2013 M6  [10.00]
** Rattle/Buzz in M Sport Steering Wheel Solved!!! **
Send me your email and I will send the procedure to you.
      06-12-2021, 12:31 AM   #4
Boosted M5
Drives: F10 m5
I'll give this a try and report back. Thanks for the link!
      08-06-2021, 01:13 PM   #5
dylonsays
Drives: F30 328 & E92 M3
This didn't fix it. It's there is a little vertical play on the shaft of the motor that causes the issue. Had the motor replaced and it didn't fix if. Going to dry another motor swap
      08-06-2021, 01:36 PM   #6
Noggie
Noggie's Avatar
Norway
292
Drives: E31 850i,i3s
I have this issue from time to time, fortunately not very often.
Having a background in electronics and automation, and about 25 years work experience with electrical systems, the sound I hear does sound like the typical squeak you get from an electrical motor that is either worn, or has a bad bearing/axial play.
I would agree with dylonsays that the problem is probably the motor.
_____________________________
-14 Imola Red M5 Competition Pack (sold)
-90 BMW 850i Supercharged
-20 i3s
-20 Ducati Diavel 1260s
      08-26-2021, 05:13 PM   #7
Dinan M6
Drives: BMW M6
2013 M6  [10.00]
Here is the google link for the file
      08-08-2023, 10:53 AM   #8
m5dream
m5dream's Avatar
Drives: f10m5
Link does not work can you DM it to me or email me Vwbulla@gmail.com
      08-09-2023, 12:07 PM   #9
m5dream
m5dream's Avatar
Drives: f10m5
Fixed my buzzing noise that I was getting at speeds over 60 over bumps and rough roads from the steering wheel. It’s the metal clip holding the vibrator in place. I simply taped to to the wheel n no noise!!
      08-15-2023, 05:11 PM   #10
m5dream
m5dream's Avatar
Drives: f10m5
update issue not fixed its the gold piece that spins that makes the buzzing sound because it has play in it up and down and somehow the way it vibrates from road bumps causes that noise..
is there a way to code out that vibrator unit all togeher?
if i unplug it it will throw a lane departure malfuction so unplugging is not a option
      08-24-2023, 07:00 PM   #11
M5_Brandoe
M5_Brandoe's Avatar
Drives: Black sapphire M5
I’ve tried “everything” to try to fix this. I have a 2013 m5, 1st and only owner. Around 4 years into ownership it started giving me this issue. BMW replaced my steering wheel 2x, components inside, and a bunch of other things… nothing fixed it. I learned to live with it, being I probably drive it about 1 month out of the year. If anyone ever resolve this let me know lol !
Instagram MRBrandoe
      08-30-2023, 12:06 PM   #12
m5dream
m5dream's Avatar
Drives: f10m5
i cant live with it
what i did was simply tape the bronze weight so it does not move up or down and i turned off the land departure system
no noise, i lose the land departrue but i can live with that as long as i dont hear that nose that makes this car sound like a rattle can.
      08-30-2023, 12:08 PM   #13
M5_Brandoe
M5_Brandoe's Avatar
Originally Posted by m5dream View Post
i cant live with it
I’ll probably be following your lead on this, until something better come along.
Thank you !
Instagram MRBrandoe
      08-30-2023, 09:52 PM   #14
MFM5
MFM5's Avatar
87
Drives: 2015 M5 CP
i cant live with it
Even with lane departure deactivated, I believe the bronze thingy spins when the a car is in your blind spot and your turn signal is on.
      09-01-2023, 10:56 AM   #15
m5dream
m5dream's Avatar
Drives: f10m5
no when u deactivate it it wont spin
      05-17-2024, 06:30 AM   #16
gfounds
Drives: E64 M6, F10 535i, F25 X3
Here’s what my “buzz” turned out to be.
Mine had been driving me crazy for a few years. It was definitely a buzz more than a rattle and occurred over course pavement or repetitive smaller bumps.
One day it was particularly bad, and I was doing what I usually do—pressing on every piece of trim I could trying to locate it. It never occurred to me until then to press on the horn/airbag assembly. Eureka! If I turned it like I was trying to turn the wheel with it and kept pressure on it, the sound disappeared. Completely.
The air bag assembly. Yep. That assembly is held in place by a metal spring type clip. You remove it (AFTER DISCONNECTING THE BATTERY) by sticking a screwdriver or similar device in a hole in the steering column and pressing on that clip. It’s metal against plastic and metal, and my best guess is that as those parts age, they just don’t fit as tightly as they did on day one. Eventually, there is enough play that they can vibrate enough to buzz.
That is definitely the source of my buzz. I will experiment with a “hands free” solution this weekend. For now, I just stop it by putting pressure on it when it occurs. I’ve replaced several steering wheels in the past, so I’m fairly confident that I can work out a hands free solution. We will see—but at least I can stop it now evening gets TOO annoying!
texsn9555.50
