05-01-2018, 05:25 PM | #1 |
Rep 469
Key fob no longer starts car
For the past few months, maybe more, my comfort access worked randomly. Some days I can walk up to car and open door without removing key from pocket. Most other days I have to use fob and unlock with button. I just got used to it.
Well today for the first time the car wouldn’t start with the key fob. Screen on dash said “no key recognized” then “hold key to colum” that didn’t work after numerous times, eventually it read it and started. I’m assuming the key fob has gone bad. I don’t believe it’s the antenna because I can still lock and unlock the car from a distance. I’ve just lost certain functions. I’m going to just go and order another key tomorrow. Lost the spare, just wanted to see if anyone has had similar key fob issues before. This is on a 14 M6 Gran coupe |
05-01-2018, 08:29 PM | #2 |
Rep 385
You just need to replace the battery inside the fob. Take out the key and pull the back cover off and you'll see the coin-type battery you can get at most stores that sell coin/hearing-aid batteries.
05-02-2018, 05:40 AM | #3 |
Rep 469
I've tried that roughly 4-5 different times. Assuming key is bad because every time I do that the car unlocks and locks it self while driving with a fresh battery.
05-02-2018, 09:57 AM | #4 |
Rep 385
Maybe. It could also be a bad comfort-access door handle sending lock/unlock messages. Without another fob to test with, this has to be diagnosed with ISTA+, which can show the lock/unlock requests from the door handles.
05-02-2018, 09:51 PM | #5 |
Rep 469
Yeah I figured I needed another fob anyway so this will hopefully fix it. If not onto the antennas and door handles.
